Wifi issue
This is a discussion on Wifi issue within the Samsung Galaxy Ace forums, part of the Samsung Android Phones category; I'm confused. Whats the difference to what the router gives me and the routers IP?...
Results 21 to 30 of 39
Thread: Wifi issue
  1. #21
    Android Lurker paulbarrett1984's Avatar
    Oct 2011
  2. #22
    Oct 2011
    When I go to cmd, ipconfig/all it gives me all the same numbers as before. Nothing has changed
  3. #23
    62 times
    Quote Originally Posted by paulbarrett1984 View Post
    DHCP on the router doles out addresses, and we are manually assigning the address. You could also try toggling your static IP address to another number, and reboot the phone (eg. 192.168.2.21) and retry. We also have to consider your encryption settings/password, but I want to ensure the IP assignments are within the specs of your existing lan/wlan. Currently, is the phone surfing after your router reset?
    Beauty is in the eyes of the beerholder
  4. #24
    62 times
    Nothing WILL change..that exercise was simply to get your lan parameters.
  5. #25
    Oct 2011
    Yes the internet is surfing after i've reset the router, but this doesn't last long.
  6. #26
    62 times
    AHA! I suspect you might have given your phone, your computer's IP address! Lets give the phone the 192.168.2.21 IP, reboot the phone and retry.
  7. #27
    Oct 2011
    Ok, i've done that, and rebooted my phone, and it appears to be connected to the internet! Hooray.... now lets see if it lasts.
    Thanks very much for all your help!
  8. #28
    62 times
    That's great! Lemme know how it holds up! :D Enjoy!
  9. #29
    Oct 2011
    It's stopped working again
  10. #30
    62 times
    Okay. On the phone, do you have or can you get a terminal app installed? We need to ping the gateway (router) from the phone. Once installed, open terminal and type 'ping 192.168.2.1' (no quotes) and enter. This will tell us if the phone is still connected to the gateway.
  1. Can't turn wifi off after turning on wifi direct. please help
    By Franklin in forum Samsung Galaxy S2
    Last Post: 12-23-2011, 01:41 AM
  2. Random issue. BIG ISSUE.
    By jgreenmusic in forum Beginning Developers
    Last Post: 09-21-2011, 10:11 AM
  3. Samsung/Sony PS3 issue HELP!!! (NO WIFI 4 THIS GUY)
    By The750iguy in forum Samsung Galaxy S2
    Last Post: 09-05-2011, 10:01 AM
  4. Sync Issue??
    Last Post: 11-25-2010, 01:15 PM
android phone keeps saying wifi not in range
my samsung phone is connecting and dsconnecting from wifi
network not in range when connecting to wifi samsung galaxy
not in range samsung
not in range samsung galaxy 2 wi-fi
phone keeps saying wifi not in range disconectting
samsung ace not in range
samsung galaxy ace keeps disconnecting from wifi
samsung keeps saying wifi not in range
samsung tablet wifi not in range
samsung wifi not in range
wifi not in range even though it is on, android
wifi not in range galaxy s2
wifi not in range in samsng tab
wifi not in range samsung ace
