Wifi issue
This is a discussion on Wifi issue within the Samsung Galaxy Ace forums, part of the Samsung Android Phones category; What is meant by a terminal app?...
Results 31 to 39 of 39
Thread: Wifi issue
  1. #31
    Android Lurker paulbarrett1984's Avatar
    Oct 2011
  2. #32
    Oct 2011
    ok, ignore that. I downloaded the app and put in what you said and it came up with "ping 192.168.2.1 (192.168.2.1) 56(84) bytes of data"
  3. #33
    Super Moderator alphawave7's Avatar
    64 times
    Okay...did it say anything else..like 45ms, or simply time out?
    Beauty is in the eyes of the beerholder
  4. #34
    Oct 2011
    That was all it said.
  5. #35
    64 times
    Quote Originally Posted by paulbarrett1984 View Post
    Try again, and hit enter/return..you should see some activity (trying to ping, success or failure).
  6. #36
    Oct 2011
    ok, i've tried again, and all it said was the same as I put above. Nothing about success or failure.
  7. #37
    64 times
    That's not right. What is your current wifi sleep policy? (Settings->Networks) Set it to 'Never' and reboot, then check your wlan settings again (should still be static), and when the phone drops connection again, fire up terminal and ping the host. Heck, ping the host WHEN you have a connection, just to see it working.
  8. #38
    Oct 2011
    When the wifi is conencted, and i type in the above, it carries on. However when the wifi is not connected, it says what I wrote above and then stops. Sleep policy is on never.
  9. #39
    Android Lurker android22's Avatar
    Nov 2011
    jB
    Dear all,
    Ever facing the wifi setting once scroll down the short cut press"wifi" the icon did not turn Wifi from OFF.
    SO u cannot connect to wifi coz wifi cannot switch on,But when u turn off ur Ace and turn it ON then u can connect.
    After restart the phone u be able to connect the wifi.
    Did someone know how its happen? and why?
  1. Can't turn wifi off after turning on wifi direct. please help
    By Franklin in forum Samsung Galaxy S2
    Last Post: 12-23-2011, 01:41 AM
  2. Random issue. BIG ISSUE.
    By jgreenmusic in forum Beginning Developers
    Last Post: 09-21-2011, 10:11 AM
  3. Samsung/Sony PS3 issue HELP!!! (NO WIFI 4 THIS GUY)
    By The750iguy in forum Samsung Galaxy S2
    Last Post: 09-05-2011, 10:01 AM
  4. Sync Issue??
    Last Post: 11-25-2010, 01:15 PM
droid incredible wifi not in range
frequent wifi disconnection on samsung ace
galaxy ace not connecting to wifi
galaxy ace wifi not in range
galaxy w says not in range for wifi
how to manually set ip address on samsung galaxy ace
samsung ace not in range
samsung galaxy ace 2 can't connect to wifi
samsung galaxy ace disconnects from wifi
samsung galaxy ace wifi keeps disconnecting
samsung galaxy ace wifi not in range
samsung galaxy not in range+wifi why
why can't my samsung galaxy ace connect to the wifi
wi fi not in range samsung
wifi always disconnect samsung galaxy ace
