Problem with Samsung Kies - Application Error
This is a discussion on Problem with Samsung Kies - Application Error within the Samsung Galaxy Ace forums, part of the Samsung Android Phones category; I installed Kies from the CD provided with the phone. But now when I double-click on the Samsung Kies icon on my desktop, it gives ...
Thread: Problem with Samsung Kies - Application Error
    Android Lurker murshid's Avatar
    Dec 2011
    Bangladesh
    2 times
    I installed Kies from the CD provided with the phone. But now when I double-click on the Samsung Kies icon on my desktop, it gives a Kies.exe - Application Error message: "The application failed to initialize properly (0x0000135). Click on OK to terminate the application." What's did I do wrong?
    Somewhere on Kamino
    83 times
    You used kies. Ok bad statement but, I suggest using Odin.
    Android Lurker kim0's Avatar
    Dec 2011
    New Zealand
    Why ODIN? That is a flash upgrade package, not something to manage the phone content, backup contacts etc.
    I found that Kies would work with Bluetooth, but not the USB cable.
    Somewhere on Kamino
    83 times
    Ok, let me explain it this way... The only reason to use Kies is for software updates. Kies is garbage that does not work properly, so, anytime someone talks about using Kies its because they want something updated. Therefore Kies and Odin do the same. If you do not want to update the device then do not use either. If you want to sync phone to a pc then first check to make sure that your pc has the driver installed on it for your device. Make sure you click on mass storage on phone when you connect to pc.
    If you want any other advice or help then comeback here and let us know. Thanks
    Android Lurker xenophobic's Avatar
    Jan 2012
    Just switch over to "Mass Storage" on your phone.Kies is a slow bloated software
    Dec 2011
    Bangladesh
    2 times
    Quote Originally Posted by xenophobic View Post
    Can you guys explain what you mean by switching over to "mass storage" and how I can do it?
    Somewhere on Kamino
    83 times
    You should be able to switch to kies or mass storage in your settings. So, click menu>settings>wireless>usb settings. You can then switch between them. Mass storage is for sending things from pc to phone or vice versa.
  1. can't see my contacts or anything in samsung kies
    By ana in forum Samsung Galaxy Ace
    Last Post: 12-24-2011, 10:53 AM
  2. Samsung Kies error
    By Shilpesh in forum Samsung Galaxy S2
    Last Post: 11-25-2011, 09:12 AM
  3. Samsung Kies error message
    Last Post: 11-19-2011, 01:19 PM
  4. Help with Samsung Kies MTP/ USB Tethering
    By shawn_fiti in forum Samsung Galaxy S2
    Last Post: 09-18-2011, 09:16 PM
  5. Cannot connect to Samsung Kies
    By parmindernangla in forum Samsung Galaxy S2
    Last Post: 09-13-2011, 12:44 AM
kies application error
kies exe application error
kies the application failed to initialize properly
kies.exe
kies.exe - application error
kies.exe application error
kies.exe application error (0xc000007b)
kies.exe error
samsung kies application error
samsung kies application failed to initialize properly
samsung kies error message
samsung kies failed to initialize
samsung kies failed to initialize properly
samsung kies says failed to initialize properly
samsung kies the application failed to initialize properly
