Docked Item Problems... PLEASE HELP
This is a discussion on Docked Item Problems... PLEASE HELP within the Samsung Galaxy Ace forums, part of the Samsung Android Phones category; Hello mates... I've beeen using Samsung Galaxy Ace for last for monthes and suddenly today, i encountered docked items problem. The items in the dock ...
Thread: Docked Item Problems... PLEASE HELP
    Android Lurker gaurav01's Avatar
    Dec 2011
    Hello mates...
    The items in the dock bar of homescreen except apps hav disappeared. Dialler,messages and contracts are no more avaliable in the dock bar and hav com out of it. Only apps is in dock bar. How can i make it like before with dialer,messages,contracts n apps all in dock bar
    Please Help me..
    Thank You.
    Gaurav
    Android Lurker johnny893's Avatar
    Dec 2011
    I know you have probably figured this out by now, but this may help someone else. Open up your phones menu, press the menu key then press edit. Drag the dialler, contacts and messaging application back into the dock. After that, press thw menu key again and press save.
    Sent from my Galaxy Ace using Tapatalk
    Android Lurker ukstan's Avatar
    Jan 2012
    I had the same problem and it turned out that , unknown to me, the icons slide back and forward so all i had to do was slide them back to where they were
    stan
  1. Problems with the HTC EVO 3D?
    By danDroid in forum HTC EVO 3D Tech Support
    Last Post: 12-28-2013, 12:00 PM
  2. HTC EVO 3D problems
    By WTFLizz in forum Android Forum
    Last Post: 09-12-2011, 08:33 AM
  3. USB problems!!!
    By Davita Tatishvili in forum Samsung Vibrant
    Last Post: 02-01-2011, 01:34 PM
  4. Problems , Problems , Problems
    By Mr Triumph in forum HTC EVO 4G Tech Support
    Last Post: 09-09-2010, 06:08 PM
change docked apps on galaxy ace
change icons on galaxy ace docking bar
dock bar galaxy ace
dock icon on samsung galaxy ace
dockbar galaxy ace
docked samsung galaxy ace
evo dock issue
galaxy ace 2 edit dock icons
galaxy ace dock problem
how to change dockbar on samsung galaxy ace
how to change the dock on samsung ace
problem encountered in samsung galaxy ace
samsung ace 2 dock problem
samsung galaxy dock bar gone
samsung galaxy dock bar problem
