Galaxy ace Will Not Work With Faulse Acrylic Nails
This is a discussion on Galaxy ace Will Not Work With Faulse Acrylic Nails within the Samsung Galaxy Ace forums, part of the Samsung Android Phones category; Hello Does anyone know if there is a way around the problem of Not being able to use the Galaxy Ace touch screen with Acrylic ...
Thread: Galaxy ace Will Not Work With Faulse Acrylic Nails
    Android Lurker jackalg1's Avatar
    Jan 2012
    Hello
    Does anyone know if there is a way around the problem of Not being able to use the Galaxy Ace touch screen with Acrylic Nails
    Ive looked in the settings but cant seem to find anything that stick out
    Many thanks
    Android Lurker xenophobic's Avatar
    Jan 2012
    Get them cut
    Somewhere on Kamino
    83 times
    You could do that or just buy a stylus.
  1. has anyone got flash 10.1 to work?
    By unintent in forum LG Ally Hacking / Development
    Last Post: 11-01-2011, 01:54 PM
  2. Anyone here work for Sprint?
    By SERPENTOR in forum Sprint
    Last Post: 06-17-2011, 01:35 AM
  3. How does appbrain work?
    By marioval in forum LG Ally Apps
    Last Post: 03-22-2011, 07:30 AM
  4. Qik Updated, Now Should Work on your Evo 4G
    By wuyanks in forum Sprint Android News
    Last Post: 07-08-2010, 10:22 AM
can any of the galaxy cell phones be used with acrylic finger nails
can i use acrylic nails on new galaxy touch screen?
can i use my nails on the samsung galaxy 3?
can the galaxy s3 be used with acrylic nails
can you use acrylic nails with the galaxy note
can you use fake nails on samsung galaxy note 3
can you use galaxys3 with acrylic nails
do acyrlic nails work with samsung galaxy s3
galaxy note 2 can you use fake nails
galaxy note can touch using fingernail
galaxy note use fake nails
samsung galaxy iii and acrylic nails
samsung galaxy note can you type with nails
type with fingernails on galaxy note
typing wth fingernails on galaxy s3
