OMG!! Galaxy FIT Does Not Recognize My Touch On Lock Screen
This is a discussion on OMG!! Galaxy FIT Does Not Recognize My Touch On Lock Screen within the Samsung Galaxy Fit forums, part of the Samsung Android Phones category; My Galaxy FIT does not recognize my touch on lock screen so not able to unlock the phone most often. after restarting again and again ...
Results 1 to 9 of 9
Thread: OMG!! Galaxy FIT Does Not Recognize My Touch On Lock Screen
    Android Lurker lokesh_1112's Avatar
    Jun 2011
    Exclamation OMG!! Galaxy FIT Does Not Recognize My Touch On Lock Screen
    after restarting again and again also it does not works, stuck on the lock screen.
    then suddenly it starts detecting touch and runs flawlessly.and after sometime same problem comes,it stuck on lock screen and dont detect touch for hours and days.
    its very annoyyiiiiiiinggg pls helppppppppp????????
    Jun 2011
    Exclamation
    i have done factory reset 3-4 times. then it started running flawless then after sometime same problem started.phone works all the function like playing music (music player started through headphone),receiving calls/sms(not able to answer the calls),syncing to gmail,twitter and i am able to see GTalk pings on status bar but not able to unlock as its touchscreen not responding.
    what you people thinks is the issue with software OR hardware????
    Please somebody help...!!
    Somewhere on Kamino
    83 times
    With the phone on pull the battery wait 30 seconds and power back on. Let us know what happens.
    Jun 2011
    Exclamation
    @SLAG IT :thanks for your response..
    Done as you said...pulled the battery while phone is on and after 30 seconds started the phone...it stuck on the lock screen again.
    i observed that it works correctly(not always) when i pull out the battery,sim and SD card for more than around 6 hours or overnight and then restart the phone,but then again after sometime suddenly stop responding to touch.
    what you think is it software problem OR hardware problem??
    will it be corrected or i will have to throw out this piece of crap???
    Please Help.......
    Somewhere on Kamino
    83 times
    Don't throw out your phone. It sounds more like a software issue to me. You can try and root. That may make it a lot better. You can wait for an update. If it was purchased within last two weeks they may let you exchange it.
    Jun 2011
    @SLAG IT :Thanks Again Dear..
    i purchased it on 13th of march 2011.it was installed with Android froyo and this problem started around 15 days back, that time i thought the problem is because of Froyo so i updated it with xxkpi Gingerbread ROM for galaxy FIT unofficially available on internet.after updating also it ran flawless for 2 - 3 days then suddenly stop responding to touch then i removed battery,SIM and SD Card and put all these back and started the phone after 10-12 hours then it started working the suddenly after 1 day stopped responding.i used to restart it most often with the hope that may be this time it will respond....sad.
    i am not aware of rooting but how rooting can improve performance??
    rooting will void device warranty??
    i am thinking of using warranty but i lost hope..for me it seems its device compatibility issue with android..dont know may be loose contact with touch screen or may be touch sensor issue or may be hardware....totally confused and worried..
    Please Help...!!
    Somewhere on Kamino
    83 times
    If you put kpi rom on your fit how did you put it on? Your already rooted. You may want to find a different rom then.
    Jun 2011
    i have updated the firmware from this site:
    How To Update Samsung Galaxy FIT S 5670 to XXKPI Gingerbread 2.3.4 Firmware | Android Advices
    but it was not responding to touch before this update also.
    after updating also it was stuck on initial setting screen with one check box asking for using location setting etc..then i removed the battery,sim and SD card and after 12 hours i restarted the phone by putting battery then device responded to touch and allowed me to do initial setting and ran flawlessly for 2-3 days then again problem occured.
    i updated the firmware through the steps mentioned in the above link without rooting.
    it wont void the warranty is it?
    one thing i observed that just after restarting when i try to unlock the device very first time unlock button blink once like it got my touch and then stop responding it seems like crashed inside.
    please suggest...
    Android Lurker carl_t0ot's Avatar
    Apr 2012
    My galaxy fit lock and unlock button isnt responding. What can I do to fix this? Its so annoying. Please respond
  1. Galaxy note does not recognize sim card
    By Pirat9690 in forum Samsung Galaxy Note
    Last Post: 02-05-2012, 05:10 AM
  2. How to change the evo 3d lock screen
    By danDroid in forum HTC EVO 3D FAQ
    Last Post: 07-01-2011, 06:03 PM
  3. OMG!! Galaxy FIT Does Not Recognize My Touch On Lock Screen
    By lokesh_1112 in forum Android Forum
    Last Post: 07-01-2011, 09:55 AM
  4. Lock Screen Question
    By Vol4One in forum LG Ally
    Last Post: 12-04-2010, 03:07 PM
  5. screen lock help needed
    By rnh in forum HTC EVO 4G Tech Support
    Last Post: 07-03-2010, 08:36 AM
galaxy fit touch not working
hardaware butuuon not working galaxy fit
how to fix screen problems galaxy fit
phone wont recognoze touch
samsung galaxy 3 not recognizing touch
samsung galaxy fit touch screen not working
samsung galaxy s3 screen not recognizing touch
samsung galaxy tablet wont recognize touch
samsung galazy wont recognize touch
samsung mega screen is locked wont let me put in passcode
samsung phone will not recongnize touch
samsung tablet wont recognize touch
sensor lock samsung galaxy fit
touch screen galaxy fit solved
touch screen phone not recognizing when i touch it
