Help Me Please
This is a discussion on Help Me Please within the Samsung Galaxy Fit forums, part of the Samsung Android Phones category; K so... After an manufactory reset my samsung galaxy fit 5670 don't recognize my finger and i'm stuck at the first step after the reset. ...
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By RobKort
  • 1 Post By furbearingmammal
Thread: Help Me Please
    Android Lurker adytza190's Avatar
    Jun 2012
    Help Me Please
    K so... After an manufactory reset my samsung galaxy fit 5670 don't recognize my finger and i'm stuck at the first step after the reset. I tried some more resets but the problem still exist. Can you help me please?
    Super Moderator RobKort's Avatar
    Apr 2012
    Pennsylvania, US
    71 times
    Are you saying that the touch screen is not working?
    -end of line-
    Jun 2012
    yes. eaven turning it off i must remove the baterry
    197 times
    FurryVarmint
    The touch screen doesn't work but the phone boots and otherwise runs normally?
    It is safe to assume that this was not sent from a computer that doesn't fit in my hand.
    DO NOT WRITE IN THIS SPACE
    Jun 2012
    yes the phone is perfectly normal from what i can see. it has no scratch or lines on the display. it just doesn't work. can it be some kind of software problem? can i do something to make it work again ?
    Apr 2012
    Pennsylvania, US
    71 times
    It is probably a software issue that might have come from the factory reset our maybe you had a bad recovery image to begin with. You will have to get a hold of a stock ROM and flash it trough ADB maybe. Not sure exactly as I'm not familiar with the phone but that's where I would start.
    -end of line-
    adytza190 likes this.
    Jun 2012
    i don't know what you're meaning. can you help me with a guide or something?
    197 times
    FurryVarmint
    It's one of two things -- the software issue Rob mentioned or a failed digitizer. The timing indicates a software issue, but a digitizer (touch screen) can go bad at any time without warning.
    First step is to reflash the ROM. If that doesn't work, you'll have to replace the phone. Good luck!
    Jun 2012
    ty i'll give it a try
    197 times
    FurryVarmint
    Good luck.
    If we can be of more specific help, let us know.
datpiff app
