Sudden Volume Spike During Call
This is a discussion on Sudden Volume Spike During Call within the Samsung Galaxy Mini forums, part of the Samsung Android Phones category; Complain to a supervisor or your carrier and get a supervisor. It's a faulty device. Remember you can get a better result if you don't ...
Super Moderator/RS
Complain to a supervisor or your carrier and get a supervisor. It's a faulty device. Remember you can get a better result if you don't yell, however, I would make sure they understood your disatisfaction. Usually a supervisor can fix your problem and be adament.
Super Moderator/RS
A few days late but I second what they said.
DO NOT WRITE IN THIS SPACE
Android Lurker
I have the same issue with a Galaxy Gio, I noticed it spikes only in 2G mode, not in 3G mode.
Super Moderator/RS
That's interesting. Any idea what data protocol the phone uses for 2G on your carrier? It might be related to that. Some of the data protocols actually use the voice system to transmit the data, so it could be interfering and will require a software update.
Android Lurker
correction, I had set the phone on 2G only. If you disable this it can use UMTS and GPRS. It now still spikes in both states. So, no difference between 2G and 3G.. What I did notice is when you end a call the volume spikes when pressing the screen. It look when holding the screen to your face might trigger the same effect. Try if it also occurs if you have earphones connected.
Waiting for the next software update..
Super Moderator/RS
You're a patient person.
Good luck!
Android Lurker
reloading firmware doesn't make any difference.. seems to be a hardware issue anyhow. sent it to a repair center, under warranty.
Super Moderator/RS
Sounds like it to me. Hopefully they'll fix it or replace it with a phone that doesn't do that.
Android Lurker
Originally Posted by
erikvr
Wow. Talk about coincidence. Hear me out please. I got sick of this issue (and what was expected to be a long warranty errand) so I ordered myself a GT-S5660 (Galaxy Gio). it wasn't that much more expensive than the ~Mini, so it sounded like a bargain. However, my issues remain with this new phone. Also, I'm getting frequent Sleep of Death's with both phones. Starting to wonder if it's the D-Link DIR-615 (rev. B2) that I have at home; some sort of incompatibility issue, so to speak. Unsure, but it's really weird. Oh, I was also thinking about that 2G and/or 3G situation, so I tried setting my phone to "Only use 2G", but issue seems to remain. Would be cool if us guys tried pin-pointing it for Samsung tech to fix. I don't feel like pushing both these phones into service, especially since they probably can't do jack about it. Any ideas guys, progress?
Reason: No profanity, even edited. :)
Super Moderator/RS
I'd recommend collecting as much information as you can and then presenting it to Samsung directly. If enough people do this they'll have to listen.
- You may not post replies
- You may not edit your posts
Forum Rules
By SweetPoison in forum Samsung Galaxy S2
Last Post: 04-21-2012, 06:39 AM
By alamosaddles in forum HTC EVO 4G Tech Support
Last Post: 10-20-2011, 04:04 PM
By droidguy in forum Sprint
Last Post: 09-02-2011, 12:52 PM
By vwhatizthiz in forum Motorola Backflip Tech Issues / Bug Reports
Last Post: 08-10-2011, 10:40 AM
By GameBoiye in forum Sony Xperia Play
Last Post: 06-14-2011, 11:48 PM
android volume spikes
disable gprs galaxy gio
s5570 can't 3g
samsung epic call volume
samsung galaxy gio voice problem
samsung galaxy gio volume audio forum
samsung galaxy gio volume code
samsung galaxy mini sound problem
samsung galaxy mini sudden volume peak
samsung galaxy mini volume spikes
samsung galaxy spike
samsung gio in call volume
samsung mini in call volume
volume samsung galaxy gio
volume spikes fix samsung
