Register
Gingerbread upgrade changes "Data Connection" to "Sound"
This is a discussion on Gingerbread upgrade changes "Data Connection" to "Sound" within the Samsung Galaxy Mini forums, part of the Samsung Android Phones category; Hi. I upgraded my Samsung Galaxy Mini from Froyo to Gingerbread and the Data connection button in the notification bar was replaced with a Sound ...
+ Reply to Thread
Thanks Tree2Thanks
  • 1 Post By atodea
  • 1 Post By henry2009
Thread: Gingerbread upgrade changes "Data Connection" to "Sound"
    Android Lurker atodea's Avatar
    Hi.
    I upgraded my Samsung Galaxy Mini from Froyo to Gingerbread and the Data connection button in the notification bar was replaced with a Sound button.
    Is there a way to get the Data connection button back? It's quite hard to access Settings > Wireless & networks > Mobile networks > Use packet data to get the same thing.
    Thanks!
    BTW, If they wanted to replace something I think Auto rotation was the best option. How often people need to change that!
    henry2009 thanked this.
    139 times
    FurryVarmint
    If you press and hold any of the buttons does anything happen?
    DO NOT WRITE IN THIS SPACE
    What buttons?
    Does this have anything to do with the "Data connection" button in the notify bar being replaced by the "Sound" button?
    Thank you.
    139 times
    FurryVarmint
    That's why I was asking.
    If you pull down the notification bar and press and hold one of the buttons for a moderate amount of time (assume 2 or 3 seconds) do you get any kind of vibration, sound, or reaction from the phone?
    I get the same result regardless of the time I press the button.
    (I get a vibration of course when I disable sound).
    Just to make sure my question is clear.
    Did you have a data connection button in the pull-down notification bar on Froyo and now (if you have Gingerbread) that button was replaced by "Sound". If so, is there anyway to get the Data connection button back?
    Thanks!
    Android Lurker henry2009's Avatar
    On my Galaxy Fit I have always had the Sound icon. I press the off button for about 1 second and you will get the data network mode connection option I tried to setup a short cut icon but could not find the Data connection short cut icon option under the Settings icon (for shortcuts)
    I have WI FI , Bluetooth , GPS, Silent , Auto rotation Icons on my Notification Bar and yes get rid of the Auto rotation bar and replace it with Data network would be great
    thoufs thanked this.
Sponsor
  1. Replies: 0
    Last Post: 07-07-2011, 11:43 PM
  2. Replies: 1
    Last Post: 07-07-2011, 02:13 PM
  3. Replies: 0
    Last Post: 05-03-2011, 12:41 PM
  4. Replies: 0
    Last Post: 03-15-2011, 11:00 AM
  5. Replies: 0
    Last Post: 02-02-2011, 03:27 PM
android data wi-fi data connection on icon
android gingerbread use packet data
change notification panel in galaxy mini
galaxy min use packet data does not work
ginger bread mobile data connection
gingerbread auto data network
how do i change the notification bar icons in gingerbread
samsung galaxy mini data connection
samsung galaxy mini data network mode
samsung galaxy mini packet data
samsung galaxy mini ses y?kseltme
samsung galaxy w packet data
samsung how to auto change data network
upgrading froyo to gingerbread in galaxy mini
use packet data shortcut
