Help my galaxy mini is flickering
This is a discussion on Help my galaxy mini is flickering within the Samsung Galaxy Mini forums, part of the Samsung Android Phones category; hello guyz i need a help.......i don't know what happen to my samsung galaxy mini i charge this last night until morning then in the ...
Results 1 to 10 of 12
Thread: Help my galaxy mini is flickering
    Android Lurker brixhacker08's Avatar
    Mar 2013
    hello guyz i need a help.......i don't know what happen to my samsung galaxy mini i charge this last night until morning then in the morning i turn off my phone to to change sim then .....when i press the power they start flickering again again !!!!! i don't know what to do so please guyz help
    but i can put it on Download Mode but Recovery mode not working because its flickering turn on then off
    Hope u will help
    Apr 2012
    230 times
    Re: Help my galaxy mini is flickering
    Take out the battery, hold it for 30 minutes, put it inside and try. If it won't work, try leaving it for a day.
    This may be a battery issue due to high voltage. Happened to me several times with the same symptoms. I had another phone with identical design, so I had a spare battery. After 5 days, I tried the original battery and it worked. Let it "rest". Hopefully, it is not permanently damaged.
    Tears for Fears
    ~~~ Guidelines of Conduct ~~~
    Mar 2013
    its happen when i charge it last night until morning...............................i dont know how can i fix it
    hope so!!!!!! maybe the battery is the problem
    same as mine watch this
    Apr 2012
    230 times
    Your phone acts like in this video? Then try reflashing the firmware through Download mode with Odin.
    Tears for Fears
    Mar 2013
    i already install the cyanogenmod 10.1 before the screen flickering......................by the way is there a chance that cyanogenmod 10.1 is cause the of my galaxy mini screen flickering.....
    Apr 2012
    230 times
    Yes, likely.
    Try a different ROM. CM10.1 is unstable yet. Try CM10, it's almost the same.
    Tears for Fears
    Mar 2013
    i can't flash some rom because when i press Home button + Power button they start blinking can't go to recovery not working!!!!!
    Apr 2012
    230 times
    First, flash a ROM either through Odin or ADB. Then flash an approved Recovery and then you can flash ROMs through Recovery.
    Tears for Fears
    Mar 2013
    ok i will try that ADB method........
    Mar 2013
    either ADB not working!!!!! im seaching for this thing i found out it cost by cyanogenmod 10.1 screen flickering
    There are time when people get screen flicker problems when flashing a new ROM. This either has to do with the ROM itself, for the kernel. Until full support is givien, I have a temporary fix. This fix is basically disabling HW overlay, but disabling HW overlay in the settings does not stick on reboot and this has been really annoying.
    For those who want to know what Disabling HW overlay is, it is basically making the phone's gpu render the graphics instead of the cpu. This allows for better graphical rendering of everything. This is not a proven statement, but theoretically, disabling HW overlay, may increase battery consumption... not by much though.
  1. Replies: 1
    Last Post: 11-19-2012, 03:47 PM
  2. Replies: 0
    Last Post: 08-21-2012, 02:23 PM
  3. Music on my Galaxy Mini
    By clee in forum Samsung Galaxy Mini
    Last Post: 12-15-2011, 01:26 PM
  4. GingerBread in GALAXY mini
    By geniiissss in forum Samsung Galaxy Mini
    Last Post: 10-14-2011, 01:08 AM
  5. Flashlight for ally - no flickering
    By doink123 in forum LG Ally Apps
    Last Post: 02-09-2011, 08:49 PM
android screen flickers at night
galaxy mini screen keep flashing
my samsung s3mini is keeping screen off
samsung galaxy mini samsung keeps flashing
samsung galaxy s3 mini screen flashing on and off
samsung galaxy s3 mini screen flickering
samsung galaxy tab 10.1 screen flicker fix
samsung mini charging flickering
samsung mini galaxy screen flicking
samsung s3 mini screen blinking
samsung tab 3 7.0 flickering screen
the screen on my samsung s2 keeps flickering
wh does my galaxy3 mini screen keep flickering
why does s3 mini screen flicker
