Galaxy Note II: Review, Tips & Tricks
This is a discussion on Galaxy Note II: Review, Tips & Tricks within the Samsung Galaxy Note 2 forums, part of the Samsung Android Phones category; Welcome To Galaxy Note II Review, Tips & Tricks The Samsung Galaxy Note 2 is the much-anticipated successor to the original Galaxy Note. The Samsung ...
Like Tree2Likes
  • 2 Post By Astrix
Thread: Galaxy Note II: Review, Tips & Tricks
    May 2012
    Lost In The Internet
    87 times
    It's a bird
    The Samsung Galaxy Note 2 is the much-anticipated successor to the original Galaxy Note. The Samsung “phablet” is already available in other. We’ve had the opportunity to spend some time with the Galaxy Note 2, and on the whole, we’re pretty impressed.
    The Galaxy Note II
    - is a bigger, beefier and more polished offering than the original Note; and
    - is guaranteed to gain some traction when it hits stores.
    Galaxy Note II Design
    - Design-wise, the Galaxy Note 2 is basically a big Galaxy S3.
    - It features the same basic design, with rounded corners, big glossy screen and thin bezel.
    Galaxy Note II Features
    - The device is powered by a 1.6 GHz quad-core Exynos 4 processor,
    - Backed up with 2GB of internal RAM.
    - 16GB of on-board storage with the ability to expand to 64 GB with a microSD card.
    - The first Samsung phone to launch with Android Jelly Bean 4.1 right out of the box.
    - Sports a 3,100 mAh battery which should yield around 12 hours of active use.
    - Power-hungry features including 4G LTE, a larger screen so effective battery life gains will be minimal.
    - The rear camera on high-performance 8-megapixel camera from the Galaxy S3; and
    - there’s a 1.9-megapixel front-facing camera for video chat.
    Galaxy Note II S-Pen
    - The Note 2 comes with the new S Pen stylus and a whole host of new S Pen features designed to enhance productivity.
    - The stylus itself has been redesigned and is wider and has flatter sides.
    - The tip now generates more friction, a change designed to make the S Pen ‘feel’ more like you’re writing on paper.
    - You simply remove the S Pen from its dock to access a bevy of new S Pen applications, among include;
    A) Easy Clip, gives you the ability to trace and crop images from your browser or photo albums and then paste the cropped content into apps or share with friends.
    B) Airview, lets you preview files such as albums, videos or calendar entries and emails simply by hovering the S Pen over them; and
    C) Quick Command, is a feature that allows you to create custom gestures so you can load your most-used apps with just a few swipes of the stylus.
    The new S Pen features are largely intuitive, but there is a lot to get your head around when you use the Galaxy Note 2 for the first time.
    UltraDroid and ohwow like this.
    May 2012
    87 times
    It's a bird
    Galaxy Note II S-Pen Apps
    Paper Artist, SketchBook, Fastest Painter, Coach's eye!
    Spider's Web
    Easy Clip
    AirView feature
    (Gallery + Video playback)
    Quick Command
    May 2012
    87 times
    It's a bird
    Android Jr Member webbjames's Avatar
    Nov 2012
    NewYork
    Thank you for sharing. The Samsung galaxy note 2 have a series of features that other phone don't have. Powerful Phone.Personally, I like it very much.
  1. Replies: 2
    Last Post: 05-31-2012, 03:44 AM
  2. A good source of tips and tricks
    By dworley70 in forum Android Forum
    Last Post: 11-01-2011, 09:32 AM
  3. A good source of tips and tricks
    By dworley70 in forum Sprint
    Last Post: 10-31-2011, 12:35 PM
  4. A good source of tips and tricks
    By dworley70 in forum AT&T
  5. Replies: 1
    Last Post: 08-18-2011, 02:03 AM
galaxy note 2 tips
galaxy note 2 tips and tricks
galaxy note 2 tips and tricks pdf
note 2 tricks
note 2 tricks and tips
samsung galaxy note 2 tips and tricks
samsung galaxy note 2 tips and tricks pdf
samsung galaxy note 2 tricks
samsung galaxy note tips and tricks pdf
samsung note 2 tips and tricks
samsung note 2 tips and tricks pdf
samsung note 2 tricks
tips and tricks for note 2
tips and tricks galaxy note 2
