MMS help!
This is a discussion on MMS help! within the Samsung Galaxy Note forums, part of the Samsung Android Phones category; I have one of those unlocked Notes and I had to change the APN settings found online in order to get the phone to work ...
Thread: MMS help!
    Android Lurker patdesignsinc's Avatar
    Jan 2012
    MMS help!
    I have one of those unlocked Notes and I had to change the APN settings found online in order to get the phone to work with AT&T. I have also installed Go SMS for texting. I noticed that most of the time when I try to send an MMS picture it doesn't go through. It just shows the arrow indicating that it's working (or the spinning wheel if I try to use Samsung's message application. Can anybody help with this?
    Sent from my GT-N7000 using Android.net
    Super Moderator CJM's Avatar
    MS Gulf Coast
    51 times
    No need to post more than once. Those wanting to help can go here: MMS Help!!!!
fix mms on unlocked note 2
galaxy note 2 mms problem
galaxy note 3 currently no mms
galaxy note 3 mms problems
galaxy note mms not working
galaxy note not sending mms
mms not downloading on galaxy note
mms not working on galaxy note
mms not working on galaxy note 2
new note 3 mms not working
note4 not getting mms
samsung galaxy note 3 mms problems
samsung note android mms not working
samsung note mms
sending a mms on galaxy note 3
