Should i enable USB debuggine for Root Galaxy Note using Clockwork mod?
This is a discussion on Should i enable USB debuggine for Root Galaxy Note using Clockwork mod? within the Samsung Galaxy Note forums, part of the Samsung Android Phones category; Hi! I need to root my Galaxy Note GT-N7000. I read few guides, all of their methods are similar ( copied XDA). However some sites ...
Like Tree2Likes
  • 1 Post By furbearingmammal
  • 1 Post By UltraDroid
Thread: Should i enable USB debuggine for Root Galaxy Note using Clockwork mod?
    Android Lurker krisoliver's Avatar
    Feb 2012
    Hi!
    I need to root my Galaxy Note GT-N7000. I read few guides, all of their methods are similar ( copied XDA). However some sites display you have to enable USB debugging before root your note using CWM? Should i do it? I don't like to bricked my device? In general knowledge i think USB debugging not necessary for clockwork mod. Am i correct?
    Thanks!
    190 times
    FurryVarmint
    Yes.
    USB Debugging should be turned on by default before root attempts.
    krisoliver likes this.
    DO NOT WRITE IN THIS SPACE
    340 times
    I agree - I always did it with my installations. Question though - why would you NOT want to enable it?
    Feb 2012
    Thanks guys your replies!
    I need to know when i on the recovery mode, USB debugging will really helpful.
  1. How to Enable Swype on Samsung Galaxy S2
    By Harumi23 in forum Android Forum
    Last Post: 05-05-2012, 01:34 PM
  2. Replies: 0
    Last Post: 02-10-2012, 09:16 AM
  3. Replies: 0
    Last Post: 01-31-2012, 10:37 AM
  4. Replies: 0
    Last Post: 10-13-2011, 11:43 AM
  5. Replies: 1
    Last Post: 06-28-2011, 01:44 AM
clockworkmod usb debugging is not enabled
enable usb debugging clockworkmod
enable usb debugging samsung galaxy note
enable usb debugging using clockworkmod
galaxy note debugging mode
galaxy note debugging offline
galaxy note enable usb debugging
galaxy note usb debug mode
galaxy note usb debugging
how to enable usb debugging on galaxy note
how to enable usb debugging on samsung galaxy note
recovery mode android usb debugging
usb debugging from clockwrok
usb debugging galaxy note
usb debugging in my galaxy note
