No Sound for Text Messages
This is a discussion on No Sound for Text Messages within the Samsung Galaxy Note forums, part of the Samsung Android Phones category; Welcome to the forum!...
Page 5 of 5 FirstFirst ... 345
Results 41 to 46 of 46
Like Tree5Likes
Thread: No Sound for Text Messages
  1. #41
    518 times
  2. #42
    Android Lurker gunnerj's Avatar
    Apr 2013
    Thanks iheartyomama, I had the same problem and your solution has solved it.
  3. #43
    Super Moderator tuxedo's Avatar
    Nov 2012
    Nashville, TN
    49 times
    Welcome to the forum gunnerj!
  4. #44
    Android Lurker numcrun's Avatar
    Nov 2015
    Quote Originally Posted by Grottis View Post
    Hi,
    There is obviously a bug in the Messagenger application.
    1. Start messager, open menu (Left of "startbutton"), select "settings", uncheck "Delete old messages".
    After this it should work. (I don't have an english GUI, so the names could be a bit diffrent!)
    Also observe:
    The "shortcut" settings found when you drag finger from top to bottom.
    The "sound icon" should NOT be green. The GUI is a bit akward, since ENABLED=GREEN means sound is OFF!
    Some cleaver guy came up with this reverse logic (enable to disable!). You can easily go wrong here!
    Good luck!
    I have had message notifications work some times but not others for a long time. Deleting all messages may have corrected the problem. It was silent for a previous message. So I deleted all messages as Grottis suggested. Then I sent a test message and got notified. I'll have to wait and see if it keeps working. Thanks Grottis.
  5. #45
    Banned Metur1987's Avatar
    Sep 2015
    Have you checked the settings, I think you might have turned off the message notification by mistake.
  6. #46
    Android Lurker dougie's Avatar
    Mar 2017
    I had the same problem I think I fixed it. Check settings Sounds and notifications " notification do not disturb make sure that its turned off
  1. Getting Text Messages Into PC.
    By NLAlston in forum HTC EVO 4G
    Last Post: 09-02-2013, 01:22 AM
  2. text messages
    By tbear in forum LG Ally Help
    Last Post: 07-29-2011, 02:35 AM
  3. text messages
    By valacuff in forum LG Ally Help
    Last Post: 04-29-2011, 02:45 AM
  4. Text Messages
    By GCinGilbert in forum LG Ally Help
    Last Post: 12-24-2010, 03:27 PM
  5. Text Messages
    By adbebbs in forum LG Ally Apps
    Last Post: 10-14-2010, 11:07 PM
android phone will not make sound with meesage
android text no sound
cant hear message tone on samsung j3 luna pro
j3 luna sound message
my samsung phone wont make a noise when i get text
my smart phone n8 wont send sound when i get a text message
no sound from text messages on android
no sound with text messages
samsung 8 does not make sound when i send a text message
samsung a3 2016 no sound when sending message
samsung a3 change message sound
samsung galaxy 8 cannot hear texts
samsung messages no sound when open
samsung phone text no sound
why do i get text notifcation when no text on android phone
