Samsung Galaxy Note WiFi Issues, Edge Speed & Upgrade to ICS
This is a discussion on Samsung Galaxy Note WiFi Issues, Edge Speed & Upgrade to ICS within the Samsung Galaxy Note forums, part of the Samsung Android Phones category; am writing from usa. bought samsung note in asia and wifi does not work. my model is gt-n7000, android version 2.3.6. when i turn on ...
Thread: Samsung Galaxy Note WiFi Issues, Edge Speed & Upgrade to ICS
    Android Lurker okusa's Avatar
    May 2012
    am writing from usa. bought samsung note in asia and wifi does not work. my model is gt-n7000, android version 2.3.6. when i turn on wifi, check marks visible both in wifi and network notification boxes. scanning starts and ends without spotting any wifi network. i tried this at home, coffee shops etc. and no such luck. what's the "fix"? also, my mobile provider is t-mobile; hence, i only get the edge, when previously, my htc connects at 3g speeds. how can i get my samsung note to 3g? finally, can i/should i upgrade to ice cream sandwich? any help would be greatly appreciated.
    Super Moderator cali's Avatar
    Sep 2011
    330 times
    Welcome to the site. Have you spoken to a customer service rep at T-Mobile?
    May 2012
    Lost In The Internet
    87 times
    It's a bird
    Welcome to the forum
    Best to upgrade to ICS. Use latest software is always good.
    For 3G, take a look on your service provider APN.
    Here example: http://support.t-mobile.com/docs/DOC-1976
    Hope it help and good luck
    May 2012
    upgraded to ics. still no luck with wifi. everytime i try and open wifi it says "turning wi-fi on" and stays there forever, then the phone hangs. if i can fix this, i can live with the edge problem.
    May 2012
    87 times
    It's a bird
    Do factory data reset. It will help to clear lots of error.
    Let us know how it go
    Administrator smalltowngirl13's Avatar
    Kansas
    67 times
    smalltownlife13
    Have you also tried to connect to multiple wifi points (different ones or is this with the same one)...coule possibly be an issue with just the one wifi spot (if you have only access to one)...
    The beatings will continue until moral improves...my new motto for work!
    Droid X Specific Site: www.droidxforums.com
  1. Samsung Galaxy Note GT-N7000 Home WiFi Problem
    By BeNaX in forum Rescue Squad General
    Last Post: 02-21-2013, 09:58 PM
  2. Replies: 2
    Last Post: 05-31-2012, 03:44 AM
  3. Issues Uploading Music Files on Samsung Galaxy Note N7000
    By cancid in forum Samsung Galaxy Note
    Last Post: 05-22-2012, 05:47 PM
  4. galaxy note wifi encryption settings
    By Hoxie2 in forum Samsung Galaxy Note
    Last Post: 04-12-2012, 06:06 AM
  5. Samsung Galaxy Note WiFi Problem
    By RajaChatterjee in forum Rescue Squad General
    Last Post: 02-15-2012, 05:37 PM
galaxy note edge wifi connection problems
galaxy note n7000 wifi problem
galaxy note wifi not working
galaxy note wifi problem
galaxy note wireless not working
n7000 wifi problem
note 2 wifi issues
note 6 edge wifi connection speed
samsung galaxy note 2 wifi issues
samsung galaxy note gt-n7000 wifi problem
samsung galaxy note wifi issue
samsung galaxy note wifi issues
samsung galaxy note wifi problem
samsung note wifi problem
what can i do if my samsung galaxy n7000 wi-fi is not working
