Problem With Email on Samsung Galaxy Note
This is a discussion on Problem With Email on Samsung Galaxy Note within the Samsung Galaxy Note forums, part of the Samsung Android Phones category; One more question, am I right in assuming that all apps will be deleted and will require re-installation? And can this situation be salvaged by ...
Results 11 to 20 of 23
Like Tree2Likes
Thread: Problem With Email on Samsung Galaxy Note
    Android Lurker BoZz's Avatar
    Jun 2012
    One more question, am I right in assuming that all apps will be deleted and will require re-installation? And can this situation be salvaged by doing a back-up and restoring from there before a factory re-set? Thank you
    May 2012
    Lost In The Internet
    87 times
    It's a bird
    When you set up after factory reset. All your apps will auto download from Google Play.
    furbearingmammal likes this.
    197 times
    FurryVarmint
    If you haven't yet, try to reinstall the ICS update. Then if that doesn't work, see if you can uninstall (or at least uninstall all updates to) the GMail app. Then update/install it again. If THAT doesn't help, you'll want to do a lot of data backup and go for the reset.
    DO NOT WRITE IN THIS SPACE
    Jun 2012
    How does one re-install ICS update?
    Thank you for helping.
    197 times
    FurryVarmint
    You download and install either ODIN or Kies, download the proper update version for your phone, and install it via ODIN/Kies. I recommend ODIN as it's a FAR superior program to Kies.
    Jun 2012
    Thank you. Please bear with me. My update was done via wifi. I however have Kies installed on my computer. I attached my phone to my computer and asked for an update and it tells me all up to date. So how can I download the update again on to my phone?
    Secondly I downloaded Odin as you said ver. 185 and installed it. Does it recognize the phone automatically or do I have to select it myself? How to proceed with the download and update?
    197 times
    FurryVarmint
    I'm not too current on ODIN, but you may want to uninstall Kies (you can install it again later) to make sure there are no problems with it. I may be totally wrong here, so proceed carefully.
    You'll need to download the update again, but a manual download link should be available in many places. Samsung or your carrier may have a direct download link on their website. Your phone will appear up-to-date in Kies because it technically is. This is why you're forcing the install via ODIN if you can.
    I will attempt to assist, but I'm no Samsung expert -- yet. I'm planning on getting Galaxy Nexus soon, so I'm sure I will become intimately familiar with the programs in question in short order. :D
    May 2012
    87 times
    It's a bird
    Quote Originally Posted by BoZz View Post
    If not familiar with ODIN..dont flash it!!!
    DO NOT INSTALL KIES..you need KIES as it drivers to recognise your Phone to use ODIN.
    Just do factory data reset.
    Jun 2012
    Thank you for the heads up. I was not going to flash it when I read that furbearingmammal has not done it himself. Maybe I should hang on a bit longer to see what happens!
    May 2012
    87 times
    It's a bird
    Yeah he try his best to assist.
    Keep us posted the outcome
  1. Samsung Galaxy Note GT-N7000 Home WiFi Problem
    By BeNaX in forum Rescue Squad General
    Last Post: 02-21-2013, 09:58 PM
  2. Replies: 2
    Last Post: 05-31-2012, 03:44 AM
  3. Problem When Receiving Call With Touchscreen with Galaxy Note
    By karnote in forum Samsung Galaxy Note
    Last Post: 02-24-2012, 02:06 AM
  4. Samsung Galaxy Note WiFi Problem
    By RajaChatterjee in forum Rescue Squad General
    Last Post: 02-15-2012, 05:37 PM
email issues with note 3
galaxy note 2 email problems
issues with download od email on samsung galaxy note 2
issues with downloading body of email on samsung galaxy note 2
note 3 email problems
samsung galaxy note 3 email problems
samsung galaxy note 4 email problems
samsung galaxy note email problems
samsung galaxy note ii email issue
samsung note 3 email issues
samsung note 3 not receiving mail
samsung note 4 email problems
samsung note email problems
samsung note mail problems
trouble with samsung note 2 e-mails
