Won't Let Me Update :-( Help
This is a discussion on Won't Let Me Update :-( Help within the Samsung Galaxy Note forums, part of the Samsung Android Phones category; Hi all, i just bought a samsung galaxy note from a local phone shop 2nd hand Its working fine but it says there is a ...
Thread: Won't Let Me Update :-( Help
    Android Lurker soundwave77's Avatar
    Jun 2012
    Its working fine but it says there is a system update available, so i click ok and it downloads and the phone re-boots but then i get a message saying
    'Failed To Update Firmware, Try Again Using PC Software (Kies)' so i have just downloaded the latest Kies, and even that says 'Your Device Does Not Support Software Upgrading Via Kies'
    Ive read around the forums and people who have 'Rooted'? there galaxy note have the same problem, how can i tell if my device is rooted? so i can update my firmware
    Any help plzzzzzzz
    Helyn xx
    Super Moderator cali's Avatar
    Sep 2011
    329 times
    Welcome to the site. Hope you get this resolved soon.
    197 times
    FurryVarmint
    Easy way to tell if your phone is rooted...
    Did you buy it from another person? If not, it's not rooted. As for updating, try downloading ODIN. It beats Kies like a drunken sailor.
    DO NOT WRITE IN THIS SPACE
    Jun 2012
    I bought the phone from a phone shop in town but the phone is 2nd hand, i downloaded that ODIN but havent a clue what im doing with it
    Jun 2012
    its ok, ive found a perfect guide how to update android galaxy note at Galaxy Note Official Android 4.0 Update for UK/Ireland -- XXLQ2
    May 2012
    Lost In The Internet
    87 times
    It's a bird
    Quote Originally Posted by soundwave77 View Post
    Do you know how to use ODIN?
    If no, read and understand which box need to check and which need to uncheck.
    ODIN is the safest way to flash...but if it fail will be disaster.
    Best to do clean install. Factory data reset in GB
    Then flash ICS..
    Gd luck and dont forget to really understand the procees before you jump in flashing game
  1. Replies: 1
    Last Post: 02-28-2012, 08:09 AM
  2. Acer Iconia Gets Update To Android 3.2 Update
    By WenWM in forum Android News
    Last Post: 08-30-2011, 05:33 AM
  3. Replies: 1
    Last Post: 01-31-2011, 12:53 AM
android failed to update firmware
android failed to update software
android software update failed
android system update problem won't let me in
failed to update firmware galaxy note
failed to update galaxy note
firmware wont update samsung android
galaxy note software update fail
galaxy note update fail
galaxy note wont update
note 3 firmware failed to update
note 4 wont let me update apps
samsung failed to update firmware
samsung galaxy note unable to update software
samsung galaxy note wont update
