Help - Email & A Few Application Problems
This is a discussion on Help - Email & A Few Application Problems within the Samsung Galaxy Note forums, part of the Samsung Android Phones category; Hi, I just bought samsung galaxy note. I encounter a few problem: 1. Email: how can i check all email and delete them? As of ...
Thread: Help - Email & A Few Application Problems
    Android Lurker bernice's Avatar
    Jun 2012
    Hi,
    1. Email: how can i check all email and delete them? As of now, im deleting 1 by 1.
    2. Running application: e.g. Im using google map for navigation, how can i set the screen would not auto switch off.
    3. How can i add/input 'chinese' in the keyboard. My current language as attached.
    Thanks.
    197 times
    FurryVarmint
    Try replacing the stock app with K9 Mail from the Play Store.
    Check Map's settings to see if there is an option to never go to sleep.
    Try this app and see if it allows you to add Chinese fonts to your phone. https://market.android.com/details?i...=search_result If not, try a different keyboard. I believe Swiftkey has Chinese and a very good predictive text engine.
    to the forum! I hope this helps!
    DO NOT WRITE IN THIS SPACE
    Jun 2012
    Thanks for the info.
    1. Will try k9 mail from play store
    2. Check, there's no 'never go to sleep'
    I even try to figure it out in phone setting.
    3. Prefer 'qwerty' keyboard if possible. Will try the app you intro. Thanks ^^
    Android Sr Member CoolDroid's Avatar
    Feb 2012
    9 times
    If you need to adjust screen on/of go to settings>display and adjust screen timeout. I think "Tasker" Androis app has an option but not sure.
    Sent from Tapatalk 2
    197 times
    FurryVarmint
    Swiftkey is QWERTY. It has a free version to try, I believe, to see if it's worth the money. Also look into Swiftkey X as it has a more robust predictive text engine.
    CoolDroid's suggestion of going into the phone settings and changing the screen timeout delay is valid.
    I use Navigation to for turn-by-turn directions, so if the screen goes off it is not a problem for me.
    Feb 2012
    9 times
    Quote Originally Posted by CoolDroid View Post
    Now I can say tasker app, has an option to set special screen timeout interval, when you run selected app.
    Sent from Taptalk.
  1. Email Problems.....
    By Toppers in forum Android Forum
    Last Post: 04-07-2012, 12:45 PM
  2. G2X Email problems
    By candydroid in forum LG G2x
    Last Post: 09-03-2011, 02:43 AM
  3. Motorola i1 Email Problems
    By bbwickstrand in forum Motorola i1 Tech Support
    Last Post: 01-03-2011, 01:32 PM
  4. Problems setting up email
    By TriciasPassion in forum Motorola Backflip
    Last Post: 11-13-2010, 09:45 PM
  5. email problems
    Last Post: 10-26-2010, 04:57 PM
applications problems galaxy note
emaol issues with galaxy note
galaxy note email issues
galaxy note email problem
happy bay
how to turn off predictive text on android
note email problems
problem samsung galaxy note
samsung android email problems
samsung galaxy email problem
samsung galaxy note email issues
samsung galaxy note email problem
samsung galaxy note email problems
samsung note email problem
swiftkey chinese
