Ringer Volume Control Issue
This is a discussion on Ringer Volume Control Issue within the Samsung Galaxy Note forums, part of the Samsung Android Phones category; Try smartvolumecontrol https://play.google.com/store/apps/d...umeControlPlus Very helpful!! My volume rocker stopped working so I installed this. A few seconds later and I an controlling the volume from ...
Results 11 to 15 of 15
Like Tree1Likes
Thread: Ringer Volume Control Issue
    Android Lurker omachrison's Avatar
    Dec 2013
    Very helpful!! My volume rocker stopped working so I installed this. A few seconds later and I an controlling the volume from the Smart Volume Control app. Better than purchasing a new phone.
    518 times
    Welcome to the forum!
    Android Lurker Billrush's Avatar
    Jan 2014
    I figured it out.
    The problem: on Note 3 (mine is ATT) you bump the volume rocker switch on the left and it switches the phone from vibrate to mute or sound. You either miss calls or your phone rings when it shouldn't.
    Solution: it is mentioned here so I installed Volume Control +, the free version. Volume Control + User guide
    It was hard for me to figure out but i think i have a workable solution. The app allows you to set a profile for the mute, vibrate and sound settings. The you lock the phones volume control and you can't change the mute,vibrate,sound from either the volume rocker or the power switch. Changes have to be made with the Volume Control + app. So I put that app as a shortcut on my lock screen. I now need to open it to change any volume setting. Instructions are marginal.
    Jan 2014
    It does work. For the first time I have confidence my phone is set correctly
    Android Lurker ponce1021's Avatar
    Feb 2014
    Use this app for lock Volume Ring
    Smart Volume Free ( lock volume ringer)
    https://play.google.com/store/apps/d...free&hl=es-419
    or
    Persist ( lock volume ringer)
  1. Media Volume control
    By Larry3961 in forum LG Ally
    Last Post: 06-30-2011, 07:11 AM
  2. Ringer/media volume switch changes
    By sherongb in forum LG Ally
    Last Post: 04-02-2011, 09:46 AM
  3. Where did my ringer and notification go to?
    By hitmanp in forum Samsung Captivate Tech
    Last Post: 10-11-2010, 08:11 AM
  4. Alarm clock and Ringer issue
    By nsalo8051 in forum Motorola Backflip Tech Issues / Bug Reports
    Last Post: 06-27-2010, 09:53 PM
android volume lock
can i lock the volume on my samsung s5
can you lock ringtone volume on samsung note 4
can you lock the volume on a galaxy note 2
everytime i hang up my ringer turns off
galaxy s4 ringer volume problem
how do you lock the volume on ringer for samsung galaxy phone
how to disable ring volume buttons of s6
how to lock the ringtone volume galaxy s6
how to lock volume button on galaxy s3
how to lock volume on samsung galaxy 5
is there any way to lock in the volume and not change it android
samsung note 3 volume issues
samsung s5 volume turns off
why is my volume button not working on my galaxy s 3
