Ringer Volume Control Issue
This is a discussion on Ringer Volume Control Issue within the Samsung Galaxy Note forums, part of the Samsung Android Phones category; I have recently switched from Nokia phones to the Galaxy Note and am finding some controls frustrating, especially the ringer voluume, agrivated by it being ...
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By RayIL
Thread: Ringer Volume Control Issue
    Android Lurker alches's Avatar
    Jun 2012
    Kalamunda Perth Western Australia
    I have recently switched from Nokia phones to the Galaxy Note and am finding some controls frustrating, especially the ringer voluume, agrivated by it being opposite the Power On/off key. (Also no camera key - so no quick photos anymore )
    The problem is, virtually every time I use the phone, I manage to turn the ringer volume off or full on - the result being missed calls or embaressment. Being opposte the power off (or sleep) it is almost impossible to 'sleep' the phone without also touching the volumne control.
    So to the questions:
    Is there a way to disable the Ringer Volume so that it only uses the default volume setting?
    Is there any way to 'sleep' the phone (lock or turn the display off) without pressing the Power button?
    Are there any apps that may control these buttons better?
    Allan
    Android Lurker RayIL's Avatar
    Aug 2012
    YES YES - Help!
    I have missed about 20 calls in last couple weeks and it's just crazy. I need way to disable the volume control - any help would be appreciated.
    Aug 2012
    Try Volume Control + Pro
    UltraDroid likes this.
    Columbia, Misery (Missouri)
    8 times
    Put "screen off and lock" app on you homescreen. You can lock the screen w//o touching the power button.
    Sent from my SGH-T989 using Android.net
    Android Lurker bigbluemav's Avatar
    Jun 2012
    Quote Originally Posted by RayIL View Post
    I had exactly the same problem and I too came from a Nokia phone.
    The above app is the go and makes the phone audible.
    Sent from my GT-N7000 using Tapatalk 2
    Android Lurker echeddar's Avatar
    Sep 2012
    No Joy
    Unfortunately, I tried the app-supported version, Volume Control +, but setting the Volume lock (even going into Settings and specifically settting it in for each volume type) doesn't prevent me from accidentally changing the volume with the hardware buttons on the left side of the phone.
    If I find an app that works to disable the hw buttons, I'll post it here.
    (Samsung Galaxy S3)
    Android Lurker gabew75's Avatar
    Sep 2012
    Question I Too Find This Very Frustrating
    Quote Originally Posted by echeddar View Post
    (Samsung Galaxy S3)
    I could do this easily on my Blackberry and find it annoying that I can't on this way superior phone otherwise. I am constantly hitting that button and jacking up my volume settings.
    Android Sr Member CoolDroid's Avatar
    Feb 2012
    8 times
    Tasker can do it.
    Sep 2012
    Lightbulb Not On The Galaxy S3 It Can't
    The button controls in Tasker don't work on the S3.
    I am now using Volume Locker so that at least when I accidentally push the button, the volume reverts to its previous setting.
    Android Lurker subhajit's Avatar
    Sep 2012
    Kolkata
    me also switch from nokia .... me also having hte same problem. and please check other if u r using note:
    1. hangs sometimes
    2. go to message-->settings-->handwriting 100% reproducible hang
    3. click on add call at the time u r in a call-->device will mute automatically
    4. click on keypad when a call is running-->no option to backspace if u write something wrong or cant able to call.
    5. call recorder not supported only your voice will get recorded.
    6. during call u cant open i)camera ii)playing songs iii)playing video which is supported on lower end S60 nokia devices its strange.
    I was a hardcore nokia user.but i thought android is better and i bought galaxy note.but this type of problems made to to think i was wrong..
    Please help
    Subhajit Sarkar
    09007070107
    subhajit_sarkar@hotmail.com
    Please help
  1. Media Volume control
    By Larry3961 in forum LG Ally
    Last Post: 06-30-2011, 06:11 AM
  2. Ringer/media volume switch changes
    By sherongb in forum LG Ally
    Last Post: 04-02-2011, 08:46 AM
  3. Volume control for bluetooth
    By jakewoodblues in forum Android Apps
    Last Post: 12-03-2010, 12:41 AM
  4. Where did my ringer and notification go to?
    By hitmanp in forum Samsung Captivate Tech
    Last Post: 10-11-2010, 07:11 AM
  5. Alarm clock and Ringer issue
    By nsalo8051 in forum Motorola Backflip Tech Issues / Bug Reports
    Last Post: 06-27-2010, 08:53 PM
disable volume button on galaxy s3
disable volume button on samsung galaxy s3
galaxy note volume issues
galaxy s3 disable volume button
galaxy s3 lock volume
galaxy s3 volume button problem
galaxy s3 volume problem
how to disable volume buttons galaxy s3
how to lock volume on galaxy s3
lock volume on samsung galaxy s3
samsung galaxy s3 disable volume button
samsung galaxy s3 lock volume
samsung galaxy s3 volume button
samsung galaxy s3 volume control
samsung s3 volume control
