Play Store Problem
This is a discussion on Play Store Problem within the Samsung Galaxy Note forums, part of the Samsung Android Phones category; Hi, I have used Samsung Galaxy Note but some i have facing problem in play store for open page. Please provide the solution. Thanks Arun...
Like Tree1Likes
  • 1 Post By Astrix
Thread: Play Store Problem
    Android Lurker Arun4985's Avatar
    Jul 2012
    Play Store Problem
    Hi,
    Thanks
    Arun
    May 2012
    Lost In The Internet
    87 times
    It's a bird
    Welcome to the forum
    Are you just upgrade to ICS?
    1) Try clear cache and data. Go to setting menu - application and find google play store and clear it. Restart your phone and try again; or
    2) Do as above, then reboot to recovery (hold 3 button combo: VolUp+Power+HomeButton till it reboot to recovery)
    - Once in recovery. Clear cache only and restart.
    3) If you just upgrade to ICS. Factory data reset will solve lots of error as it a major update from GB to ICS.
    4) Are your rooted? If yes, fix permission in recovery.
    Gd luck and hope it help
    CR6 likes this.
    Android Lurker DCKiller's Avatar
    May 2013
    Quote Originally Posted by Astrix View Post
    Hi i think i now your problem.
    go to application then all you see all the way down on page playstore blocked un block and don..
  1. @ METRO App Store
    By jslim454 in forum MetroPCS
    Last Post: 11-09-2013, 10:39 PM
  2. Replies: 0
    Last Post: 05-25-2012, 10:36 AM
  3. HTC App store? Could be in the making
    By Cedric in forum Sprint Android News
    Last Post: 11-09-2010, 01:57 PM
  4. Anyone on here work at an AT&T Store?
    By dandroid in forum AT&T
    Last Post: 08-28-2010, 05:25 PM
  5. Where tp buy Evo Sprint Store vs Best Buy
    By ceabbott2 in forum Sprint
    Last Post: 06-30-2010, 10:19 AM
android play store will not open
galaxy note 1 play store
galaxy note 4 problems and fixes playstore wont work
google play store not responding note 2
google play store not working on galaxy note 3
note 2 play store not working
play store problems note 2
playstore problem
samsung galaxy note 2 play store not working
samsung note 1 play store
samsung note 1 play store not working
samsung note 2 play store not working
samsung note play store not working
samsung play store not working
why no google play for galaxy note 2
