Hi
i just upgrade my galaxy note to ICS, i found out that my battery fast to die. What shall i do?
This is a discussion on Problem with Battery within the Samsung Galaxy Note forums, part of the Samsung Android Phones category; Hi i just upgrade my galaxy note to ICS, i found out that my battery fast to die. What shall i do?...
Hi
Can you access the battery settings and either take a screen shot or tell us what's been using the battery the most?
Sent from my SCH-I535 using Tapatalk 2
DO NOT WRITE IN THIS SPACETHIS SPACE INTENTIONALLY LEFT BLANK
Its normal for ICS. Fast OS and battery hungry
Try to use Juice Defender from Google Play Store.
