Hi All
I just bought a 3250maH battery for my Note.
Ebay, from Hong Kong for A$12.
I'll report in if it's any good.
This is a discussion on 3250maH Battery within the Samsung Galaxy Note forums, part of the Samsung Android Phones category; Hi All I just bought a 3250maH battery for my Note. Ebay, from Hong Kong for A$12. I'll report in if it's any good....
Hi All
There's been cases where they put the label over the lower version of battery power pretending to be higher power. Did you look under the battery to see if it correspond? Does it last much longer? If it's good, which company? Thanks.
Sent from my GT-N7000 using Android.net
12 bucks isn't much, i wouldn't expect a whole lot of life from it. We had a couple people on the S3 forum buy cheap extended batteries from china and they didn't last any longer than the stock battery. Buyer beware, this is one instance where you get what you pay for. That battery should have cost around 40- 50 bucks.
tap'n
