Battery Drain
This is a discussion on Battery Drain within the Samsung Galaxy Note forums, part of the Samsung Android Phones category; My Galaxy note start battery drain after upgrade to ICS is there a solution for that problem Sent from my GT-N7000 using Android.net...
Thread: Battery Drain
    Android Lurker hesham.derbala's Avatar
    Nov 2012
    Battery Drain
    Android Lurker huotg01's Avatar
    Nov 2012
    Montreal, Canada
    huogas
    I found difficult to go for 12 hours with one charge on my Galaxy Note. I don't think it is directly related to ICS, there is so many reasons for that situation, some related to LTE versus 4G, some related to the way you sync, etc.
    Anyway, I finally decided to buy on eBay 2 more batteries and a charger, all that for about 25$. Since that time, my life is a lot simpler...
  1. Replies: 1
    Last Post: 03-20-2012, 04:55 PM
  2. Yahoo Email/Battery Drain
    By BroadSword in forum LG G2x
    Last Post: 09-15-2011, 03:17 AM
  3. Will enabling GPS drain alot of battery??
    By faynay in forum HTC EVO 4G
    Last Post: 07-20-2010, 12:22 AM
android 4.1.2 galaxy note battery drain
android battery drain
fast drain note n7000
fast samsung galaxy tab battery drain solution
galaxy note n7000 battery drain
is there a virus that kills my battery on my samsung note 3
my gps on my samsung note 2 drains my battery
samsung droid battery drain
samsung galaxy note battery drain
samsung galaxy note n7000 battery drain
samsung note upgrade battery drain
upgraded android cause batery drain faster
what is the reasons for draining battery fast on samsung galaxy note gtn7000
why is my galaxy note battery draining
why is my samsung galaxy note battery drain
