Note Will Not Shut Off When Charging
This is a discussion on Note Will Not Shut Off When Charging within the Samsung Galaxy Note forums, part of the Samsung Android Phones category; Hi All New here do direct me if breaking with any protocol. Have a SGH-1717r note and it will not turn off or stay off ...
Results 1 to 10 of 13
Like Tree4Likes
Thread: Note Will Not Shut Off When Charging
    Android Lurker Hopeless's Avatar
    Dec 2012
    Toronto
    Unhappy Note Will Not Shut Off When Charging
    Hi All
    Have a SGH-1717r note and it will not turn off or stay off once I plug it in to charge it. Had this happen once before but cannot recall what I did to fix it. Was a reset of some kind.Any step by step instructions would be great help. Thanks.
    519 times
    Hi Hopeless - welcome to the forum!
    Hopeless likes this.
    May 2012
    Lost In The Internet
    87 times
    It's a bird
    re: Note Will Not Shut Off When Charging
    Go to setting - developer options - uncheck Stay awake
    Dec 2012
    Toronto
    Not an option
    Quote Originally Posted by Astrix View Post
    Hi and thanks for your responce. I do not have stay awake as an option. Any other ideas?
    Thanks
    Super Moderator cali's Avatar
    Sep 2011
    329 times
    Welcome to the site.
    Super Moderator RobKort's Avatar
    Apr 2012
    Pennsylvania, US
    75 times
    Re: Note Will Not Shut Off When Charging
    Check your display time out settings. Welcome aboard.
    .........TPT'd From my SGS3
    Super Moderator CR6's Avatar
    Idaho
    222 times
    There's also an option that you'll have to go into system settings to disable where you have it set to stay on while charging.
    Turn that off and you're good to go!
    Welcome aboard!
    tap'n
    Dec 2012
    Toronto
    Told you I was hopelss
    Quote Originally Posted by CR6 View Post
    Welcome aboard!
    tap'n
    Hi again.
    No go. I should add that I am on the Rogers network, also if the phone is turned of as soon as I plug it into the charger it turns it self on. Before I did the update when I lpugged it in just a chargeing battery icon came on breifly then went out.
    519 times
    My OG Droid (a Motorola phone) used to do that. No biggie - I mean, it wasn't a problem. Does it cause problems for you?
    Apr 2012
    Pennsylvania, US
    75 times
    You might want to try a factory reset then. It might be a bug due to the upgrade.
    ...... TPT'd from my A500
  1. How Do I Turn Off the Start Up/Shut Down Noise?
    By catburglar in forum Samsung Galaxy Mini
    Last Post: 03-25-2012, 06:15 AM
  2. Feds Shut Down Megaupload
    By cereal killer in forum Android News
    Last Post: 01-19-2012, 07:15 PM
  3. Charging the galaxy note with an iPad charger?
    By fire_storm in forum Samsung Galaxy Note
    Last Post: 12-05-2011, 01:59 AM
  4. Verizon Chime won't shut off
    By angel_lgally in forum Introductions & Site Assistance
    Last Post: 08-25-2010, 11:06 AM
android note 4 screen staying lit
android power off while charging
my note 1 does not go off when am charging
note 3 backlight wont go off
note 3 wont close while charging
note 4 screen on while charging
note 4 screen wont turn off when charging
note 4 staying on while charging
note 4 warning light while charging
phone does not sleep when charging note 3
samsung galaxy note 4 screen will not poweroff when charging
samsung note 3 display won't turn off when charging
why does my note 5 stay on when charging
why note 3 will not go off during charging
why note 4 rom cannot power off charge
