Big problem !!
This is a discussion on Big problem !! within the Samsung Galaxy S forums, part of the Samsung Android Phones category; Hi all. Please help me. I made a HARD RESET of my phone galaxy s advance. I put out my sim card. Now, on the ...
Results 1 to 8 of 8
Thread: Big problem !!
    Android Lurker jacoobs96's Avatar
    Mar 2013
    Big problem !!
    Hi all. Please help me. I made a HARD RESET of my phone galaxy s advance. I put out my sim card. Now, on the screen , i have: Downloading, dont turn off. Please what i have to do now ?! Im waiting and waiting and nothing changes :/
    Super Moderator CR6's Avatar
    Idaho
    222 times
    Re: Big problem !!
    Welcome to the forum!
    Did you remove the SIM card after you did the factory data reset, or during?
    tap'n
    Mar 2013
    Odp: Big problem !!
    I removed it before I did that
    Idaho
    222 times
    Re: Big problem !!
    That's not good, you need to leave the SIM card in the phone when performing a reset like this. Is there a reason you removed it first? Not sure how to fix this....you may have to Odin back to stock. Hang in there and hopefully someone else can offer their opinion on the matter.
    tap'n
    Mar 2013
    Odp: Big problem !!
    Can I do reset once again? how can I improve it now ???
    Mar 2013
    Odp: Big problem !!
    What have I to do with Odin ?
    Apr 2012
    230 times
    Your phone has entered Download Mode. Ignore the sign "Don't turn off", pull out the battery, put it back in then turn on the phone. This "Don't turn off" sign is only meant for when you are installing an update, currently, your phone is only prepared to install an update, but is not installing anything. You've probably probably held Volume Down key when holding Power key, because this is how you enter the Download Mode.
    Tears for Fears
    ~~~ Guidelines of Conduct ~~~
    519 times
  1. GPS problem.
    By d3one in forum Nexus S
    Last Post: 09-27-2011, 12:47 PM
  2. cm rc6.1 problem
    By tonybhoy in forum Nexus One Development & Hacking
    Last Post: 11-16-2010, 03:01 AM
  3. Qik problem!!!
    By usaflt in forum HTC EVO 4G Tech Support
    Last Post: 10-09-2010, 11:43 PM
  4. 3g problem
    By tonybhoy in forum Nexus One Tech Issues / Bug Reports
    Last Post: 06-28-2010, 04:00 PM
big thumbnail problem on android
