EDGE not working after installing Widgetsoid.
This is a discussion on EDGE not working after installing Widgetsoid. within the Samsung Galaxy S forums, part of the Samsung Android Phones category; Hi,
I used EDGE for a while and decided to install Widgetsoid to easily enable/disable data use. Once installed, I could not get EDGE to ...
Android Lurker
Hi,
I used EDGE for a while and decided to install Widgetsoid to easily enable/disable data use. Once installed, I could not get EDGE to work again.
Tried all settings and ended up uninstalling, resetting APN settings and re-entering the APN (and I restarted and tried to use EDGE between every step). I am sure the APN settings are correct, and that the APN is toggled (radio button is green).
Can someone help me here or do I have to reset the whole phone?
- Oskar
Android.net is the premier
- You may not post replies
- You may not edit your posts
Forum Rules
By henry2009 in forum Samsung Galaxy Fit
Last Post: 10-19-2011, 07:47 AM
By kingsolomon in forum Rescue Squad Help
Last Post: 07-06-2011, 01:56 AM
By Chrysolite in forum Rescue Squad Help
Last Post: 06-19-2011, 10:26 PM
By wicked in forum Android News
Last Post: 03-04-2011, 12:37 PM
By Leigha in forum HTC EVO 4G
Last Post: 03-02-2011, 07:19 PM
android edge not working
android widgetsoid galaxy s2
edge android green not working
elixir 2 vs widgetsoid
elixir vs widgetsoid
galaxy s 2 widgetsoid stopped working
galaxy s2 elixir flash
galaxy s2 internet not working on edge
how to use edge on android
how to use edge on galaxy s 2
how to use samsung galaxy fit edge
internet widgetsoid
the edge android not working
what is edge.... how to use this in galaxy fit
widgetsoid data not working
