Mobile Hotspot Issues and Temp Workaround
This is a discussion on Mobile Hotspot Issues and Temp Workaround within the Samsung Galaxy S2 forums, part of the Samsung Android Phones category; Hi I have Galaxy S II SGH-T989 on T-Mobile with Android 4.1.2 and Mobile hotspot plan paid for (phone unlocked). After updating to 4.1.2 (official ...
Thread: Mobile Hotspot Issues and Temp Workaround
    Android Lurker darusf's Avatar
    Aug 2013
    After updating to 4.1.2 (official update) I started having issues with the mobile hot spot.
    1) I turn on the hostpot in the morning
    2) connect fine with my notebook
    3) canít get past the gateway, ipconfig release / renew, nothing, can't ping beyond the gateway
    4) reboot the phone and go back to step 1 and 2, hotspot starts working fine, I can connect to the internet with no issues
    5) I turn off the hotspot for the rest of the day to conserve battery
    6) in the afternoon I turn the hotspot back on, same issue comes back, I can connect to the hotspot with my computer but no access beyond the gateway
    Workaround I found
    At this point I can turn on the Airplane mode, after it turns on, I turn it back off and then turn on the hotspot. Then I can connect and access the internet with no issues.
    Its a major pain and annoyance to have to keep turning on and off the Airplane mode along with hotspot just to connect and access internet via my notebook. I have to do it twice a day for my commute.
    Anyone else experiencing same issue or has a fix?
    Thanks
    Super Moderator cali's Avatar
    Sep 2011
    330 times
    Not experiencing exact issue, but something similar with broadband device. Sometimes takes quite some time (annoying) and a reboot or even two, before the device works. Have not found a workaround. BTW, welcome to the site.
    518 times
    I'm not a technician either, so I can't help you on that point, but we have some really knowledgeable members and staff, so if you can stick around you should get some suggestions on how to solve your problem.
    197 times
    FurryVarmint
    Does toggling just your data access fix the problem? I have a similar issue with my phone and just turning the data off and on again usually fixes the issue. Also only takes fix seconds instead of thirty.
    Sent from my SCH-I535 using Tapatalk 2
    DO NOT WRITE IN THIS SPACE
    Somewhere on Kamino
    83 times
    What fuzzy said. The reason also it connects to hotspot is the hotspot when turned on is broadcasting a signal. Treat it like having a cellphone without paying your bill. It can turn on but you can't make any calls.
  1. 4G Mobile Hotspot Hack
    By shockwave72 in forum Android 2.3
    Last Post: 06-08-2012, 08:28 AM
  2. 3G Mobile Hotspot
    By allyAndroid in forum LG Ally
    Last Post: 03-21-2011, 06:21 PM
  3. Mobile hotspot after 2.2 update
    By wrath_00 in forum LG Ally Apps
    Last Post: 02-05-2011, 09:39 AM
  4. 3G Mobile Hotspot
    By Ak8s_lgally in forum LG Ally Help
    Last Post: 01-27-2011, 02:43 PM
  5. Mobile hotspot question for T-mo
    By latinfavio in forum T-Mobile
    Last Post: 11-17-2010, 09:34 AM
can'tturn on hotspot after updating my sgh t989
hot sport not turning on samsung avant
how to on hotspot in samsung galaxy s3 i535
how to solve the hotspot problem in samsung sch i535
how to unlock mobile hotspot in samsung sch-i535
lg ally 3g mobile hotspot
mobile hotspot not working on s3 535
s2 t989 hotspot not working
samsung galaxy avant hotspot not working
samsung galaxy s2 hotspot not working 3g cuts off
samsung siii sch-i535 hotspot not working after upgrading
sch i535 hotspot solution
sch-1535.hotspots problems
sch-i535 hotspot problem solution
which hotspot device works in cleveland ohio
