Galaxy S2 Running HOT
This is a discussion on Galaxy S2 Running HOT within the Samsung Galaxy S2 forums, part of the Samsung Android Phones category; Hi, i did have this happened to me once. My very went really warm and i turned it off and on again and also deleted ...
Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 121 to 130 of 136
Like Tree1Likes
Thread: Galaxy S2 Running HOT
  1. #121
    Android Lurker marilynlanza's Avatar
    Apr 2012
    Hi, i did have this happened to me once. My very went really warm and i turned it off and on again and also deleted an app i had downloaded and its been fine since
  2. #122
    Android Lurker Sonoglee's Avatar
    Feb 2012
    I have this problem. In fact I think that my phone is usually warmer than any other phone I've had. Occasionally it gets too hot to touch around the camera area.
    Sent from my SGH-T989D using Android.net
  3. #123
    Android Lurker rgholston4435's Avatar
    Apr 2012
    Mine was running hot and i returned it to the store and they replaced it.....i later went to Milaysia for a business trip and got this galaxy note........but take it in...my sugestion
    Sent from my GT-N7000 using Android.net
  4. #124
    Android Lurker BenitoKnickman's Avatar
    Apr 2012
    India
    Yes i also have same problem. When i charged my phone in Car then it gets hot in a very short spam of time.
  5. #125
    Android Lurker Trey24Tiger's Avatar
    Apr 2012
    i have galaxy s2 my phone is of gh-68 batch and has the same problem not only this
    my phone get hot and starts beaping which scares the hell out of me
    it was so hot that it had to take its battery out
    i cant even handle it for few minutes
    "seems like its going to burst as these kind of news are common now a days"..
  6. #126
    El Paso, TX
    59 times
    _B0BB0_
    What's the temp? Use an app like System monitor.
  7. #127
    Android Lurker TechFitGJ's Avatar
    Apr 2012
    Philadelphia, PA
    S2 with AT&T. no heat issues here.
  8. #128
    519 times
    Same here. Same phone, same carrier, no issues.
  9. #129
    Android Lurker zee786's Avatar
    May 2012
    Quote Originally Posted by etcromb View Post
    Has anyone had an issue with their phone running hot?
    I have had to remove the battery a couple of times since receiving it last Thursday. It ran hot, twice after charging via the car charger and one time I just had it in my pocket. When it runs hot it freezes . The heat does not appear to be around the battery but higher, towards the camera.
    Once the battery is removed, I have replaced it immediately and the phone then runs perfectly.
    Confusing.
    hi guys i got samsung sg2 and i had same heating problem with my fone too.been searching around from good few months now butt no luck!so i came a cross a little experiment ang guess what it realy worked and did the MAGIC about heating problem with my sg2.well i thought i should share it with you guys hopefully it will help you guys too.well the problem with heating up when charging is BATTERY!as far as i knw its got nothing to do with any app or any thing.coz im a computer and fone geek lolz.neway to get around with it is first thing is you really have to do is CONDITIONING your battery.then putt your fone on charge and repeat this for atleat 3 times and guys u will see the MAGIC about your heating problem on chargin.coz no need to change your batery and run around to get your fone repaird.after conditioning your battery not only you will solve your heating problem butt you will get max out of you battery too!so guys its worth a shot coz it worked perfectly fine for me.soo goodluck.and yeh i forgot i found a best sloution with heating problems while playing games and using your fone too much.so any questions feel free to write back!
  10. #130
    Android Lurker coolvai.p's Avatar
    May 2012
    So howz ur Note working? Does it have same heating problems like s2? M also planning to buy a note? Is it worth the money?
    Thnx in adv..
    Sent from my GT-I9100 using Android.net
  1. Why More Services Are Running in RAM
    By rajeshgalla in forum Samsung Galaxy
    Last Post: 02-26-2012, 12:03 AM
  2. Replies: 0
    Last Post: 10-16-2011, 10:50 PM
  3. Replies: 0
    Last Post: 09-07-2011, 04:58 AM
  4. Running Services
    By GrahamF in forum Android Forum
    Last Post: 03-14-2011, 04:31 AM
  5. What rom are you running on the EVO 4G?
    By danDroid in forum HTC EVO 4G Hacks
    Last Post: 12-10-2010, 09:56 PM
galaxy s2 cpu runs hot
galaxy s2 hot
my samsung galaxy s2 gets really hot
s2 hot
samsung galaxy hot
samsung galaxy s2 gets hot
samsung galaxy s2 getting hot
samsung galaxy s2 hot
samsung galaxy s2 running hot
samsung s2 gets hot
samsung s2 getting hot
samsung s2 hot
why does the samsung galaxy s2 android get hot
why does the samsung galaxy s2 get so hot
why is my samsung s2 so hot
