Galaxy S2 Running HOT
This is a discussion on Galaxy S2 Running HOT within the Samsung Galaxy S2 forums, part of the Samsung Android Phones category; Well,...lets face it we all bought The Biggest Samsung ever, Best High End phone on the market...and its geting hot !!!!!, and its has Low ...
Page 2 of 14 FirstFirst 123412 ... LastLast
Results 11 to 20 of 136
Like Tree1Likes
Thread: Galaxy S2 Running HOT
    Android Lurker avedis's Avatar
    Jun 2011
    Well,...lets face it we all bought The Biggest Samsung ever, Best High End phone on the market...and its geting hot !!!!!, and its has Low Wi -Fi recepsion, and music playbeck ....far away from good ones ......
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Quote Originally Posted by Droid-Xer View Post
    How hot is hot? Use an app like temp monitor to check.
    Well, from what I've seen out of mine, hot is usually around 47-52c. Honestly though, it's so thin it's like the CPU is right on your hand... not much thermal insulation between the insides and your hand.
    That said, I've seen much higher temps before, and around 50-52 is the high side of normal. Any hotter and it stops charging to cool down.
    Sent from my SGH-I897 using Tapatalk
    El Paso, TX
    59 times
    _B0BB0_
    I've found out through my own stupidity that between 120-125f (~50c) is my Droid x max temp before cool down mode is enabled. I know most processors are ok up to ~160f before total meltdown. Its normal for most stock phones to run up to 110f
    197 times
    FurryVarmint
    At the speed the CPU is being pushed at, yes. Especially with data streaming. It is a microwave oven, after all.
    Microwaves broadcast in the 2.4GHz frequency band.
    DO NOT WRITE IN THIS SPACE
    El Paso, TX
    59 times
    _B0BB0_
    My xoom at 1.7ghz can boil ramen noodles.
    Dorian likes this.
    197 times
    FurryVarmint
    Well, I think Xer just outed himself as a major geek. :D
    El Paso, TX
    59 times
    _B0BB0_
    What you guys don't have the boil ramen app??
    Jun 2011
    Guys do you thing all thies issues can be fixed by a software upgrade?
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Quote Originally Posted by avedis View Post
    Software updates can help with the heat issue... kernel optimization helps a good bit, and a new kernel version is included in most updates. But I wouldn't expect it bring the temps down much, if you're keeping it at 1.2GHz or overclocking it.
    EDIT: Ninja post!
    197 times
    FurryVarmint
    Some. The phone's always going to run a little hot, though.
    They fixed a lot of the heat issues on the Droid 1 through upgraded software.
  1. Why More Services Are Running in RAM
    By rajeshgalla in forum Samsung Galaxy
    Last Post: 02-26-2012, 12:03 AM
  2. Replies: 0
    Last Post: 10-16-2011, 10:50 PM
  3. Replies: 0
    Last Post: 09-07-2011, 04:58 AM
  4. Running Services
    By GrahamF in forum Android Forum
    Last Post: 03-14-2011, 04:31 AM
  5. What rom are you running on the EVO 4G?
    By danDroid in forum HTC EVO 4G Hacks
    Last Post: 12-10-2010, 09:56 PM
galaxy s2 cpu runs hot
galaxy s2 hot
my samsung galaxy s2 gets really hot
s2 hot
samsung galaxy hot
samsung galaxy s2 gets hot
samsung galaxy s2 getting hot
samsung galaxy s2 hot
samsung galaxy s2 running hot
samsung s2 gets hot
samsung s2 getting hot
samsung s2 hot
why does the samsung galaxy s2 android get hot
why does the samsung galaxy s2 get so hot
why is my samsung s2 so hot
