Galaxy S2 Running HOT
This is a discussion on Galaxy S2 Running HOT within the Samsung Galaxy S2 forums, part of the Samsung Android Phones category; Lowering the screen brightness will help the temp drop a bit....
Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 136
Like Tree1Likes
Thread: Galaxy S2 Running HOT
  1. #21
    El Paso, TX
    59 times
    _B0BB0_
  2. #22
    197 times
    FurryVarmint
    THAT is a good tip. I never would have thought of that.
    DO NOT WRITE IN THIS SPACE
  3. #23
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    ^Indeed. It's especially true with Super AMOLED screens. For some reason they make quite a bit of heat with the screen brightness turned up.
  4. #24
    197 times
    FurryVarmint
    Well, they do say that LEDs generate more heat per watt than incandescent bulbs. I don't see how, but that's what I've heard.
  5. #25
    krk
    krk is offline
    Android Lurker krk's Avatar
    New processors or software always carry new issues. We roasted a new 5Kw PSU by porting software over from the old model as suggested by the hardware folks. Took weeks to understand what was going on and get it working!! I guess this is a similar problem. The software sounds to be everything full on at all times with no throttling to balance the load. Is battery life poor or is the problem only happening when external power is available?
    Sent from my Nexus S using Android.net
  6. #26
    Android Lurker karanc's Avatar
    Jun 2011
    My Fone is running HOT too but not in the Battery area so the App is of No use & can any one tell me if this Problem is covered under the Warranty (i have not rooted my Fone)??? & ya Becoz of that my Battery is Dieing tooo fast!!!!!
  7. #27
    197 times
    FurryVarmint
    Take the phone back and ask for another one.
  8. #28
    Somewhere on Kamino
    83 times
    +1 I agree with Fbm. If your not happy or device isn't working properly return it.
  9. #29
    Android Lurker davieboy1982's Avatar
    Jun 2011
    hey everyone check your galaxy s2 batch number on the inside of the box both my batches have been dodgy one with very weak disconnecting wifi and one with a oven built into the unit that burns ya ear and ya ass when ya have it in ya back pocket batch number is......... Gh69-12988a..... If your is the same and heats up fast and same batch number as above samsung has to recognize this batch as faulty many thanks ;-)
  10. #30
    Android Lurker FireDiamond's Avatar
    Jun 2011
    Running Hot
    Maybe nothing, but my last phone was a Nokia 5500 and it got hot whilst on the internet. So I thought nothing of my new S2 getting hot also, whilst on the internet and playing video files. The heat is quite noticeable though, at the top by the camera as mentioned. It scared the hell out of me when I feel the growing heat in my shirt pocket, took the phone out and realise that I'd forgotten to close an app or two. If it doesn't get worse then I'll stick with it.
  1. Why More Services Are Running in RAM
    By rajeshgalla in forum Samsung Galaxy
    Last Post: 02-26-2012, 12:03 AM
  2. Replies: 0
    Last Post: 10-16-2011, 10:50 PM
  3. Replies: 0
    Last Post: 09-07-2011, 04:58 AM
  4. Running Services
    By GrahamF in forum Android Forum
    Last Post: 03-14-2011, 04:31 AM
  5. What rom are you running on the EVO 4G?
    By danDroid in forum HTC EVO 4G Hacks
    Last Post: 12-10-2010, 09:56 PM
galaxy s2 cpu runs hot
galaxy s2 hot
my samsung galaxy s2 gets really hot
s2 hot
samsung galaxy hot
samsung galaxy s2 gets hot
samsung galaxy s2 getting hot
samsung galaxy s2 hot
samsung galaxy s2 running hot
samsung s2 gets hot
samsung s2 getting hot
samsung s2 hot
why does the samsung galaxy s2 android get hot
why does the samsung galaxy s2 get so hot
why is my samsung s2 so hot
