Galaxy S2 Running HOT
This is a discussion on Galaxy S2 Running HOT within the Samsung Galaxy S2 forums, part of the Samsung Android Phones category; Exchanged my S2, this one isn't as bad imo What games would you recommend for the S2? Also what does Launcher Ex do in terms ...
Page 8 of 14 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 136
Like Tree1Likes
Thread: Galaxy S2 Running HOT
  1. #71
    Android Lurker Fshakeey's Avatar
    Also what does Launcher Ex do in terms of keeping the phone cooler?
  2. #72
    Android Jr Member ELL4EVER's Avatar
    UK
    Stardunk is an addictive game.
    As for th launcher program, you can customize things like transition speed so th phone runs smoother
    Sent from my GT-I9100 using Android.net
    Posted from my epic galaxy S2 ^_^
  3. #73
    197 times
    FurryVarmint
    Any 3rd-party launcher will disable a lot of the background processes that constitute the skin running on the phone -- MotoBlur on Motorola phones (not-so-affectionately called MotoBloat), Sense on HTC phones, and Touchwiz on Samsung phones.
    DO NOT WRITE IN THIS SPACE
  4. #74
    Quote Originally Posted by ELL4EVER View Post
    Is the game good? It doesn't seem that good since I'm not really into basketball
  5. #75
    UK
    Yeh its pretty fun, Im not into basketball either but this game is pretty cool
  6. #76
    Android Lurker Maze's Avatar
    I am new to Android and to the forum...I have been having similar heat issues. Today with no apps running, wifi off, gps off, display on low, etc the phone got hot in my pocket. This happened shortly after running a wifi analyzer app. I then went into the active applications and verified that no apps were active, then to RAM manager and did a clear memory. It said that it closed 20 applications, and the phone cooled down almost immediately. Not sure if something hung-up when I closed the wifi analyzer app and turned off the wifi or not.
  7. #77
    Columbia, Misery (Missouri)
    8 times
    If you needed to exchange it then that's what you do. I want to inform you though that 124 is acceptable and don't be suprised if the Sensation gets that hot. As long as the phone stays under 150 they are within specs.
    Maybe my Optimus hasn't the ability to work that hard, or I'm not asking enough of it. My battery temp has never gotten above 39 F.
  8. #78
    Oh right okay thanks a lot :]
    I was wondering what browser you think is best? Opera or dolphin?
    Know any good apps? Don't have many :/
  9. #79
    Super Moderator CR6's Avatar
    Idaho
    222 times
    Quote Originally Posted by titanoman View Post
    You mean 39 celcius right?
    tap'n
  10. #80
    8 times
    Quote Originally Posted by CR6 View Post
    tap'n
    No. I just read your post and checked battery status. It's 38.76F right now. I've been in forum for about an hour and power-amp playing in the background -loud- and a few call interruptions. I'm sure I have 30 apps running in the background. The back of the phone (no silocone) is sligjtly warm to the touch:http://i.imgur.com/pgh.Gn.png
    Oh. And I also just used Shootme, gallery and imgur.
    Ohhh...where's my shot? Take my word.
    Sent from my LG-P509 using Android.net
  1. Why More Services Are Running in RAM
    By rajeshgalla in forum Samsung Galaxy
    Last Post: 02-26-2012, 12:03 AM
  2. Replies: 0
    Last Post: 10-16-2011, 10:50 PM
  3. Replies: 0
    Last Post: 09-07-2011, 04:58 AM
  4. Running Services
    By GrahamF in forum Android Forum
    Last Post: 03-14-2011, 04:31 AM
  5. What rom are you running on the EVO 4G?
    By danDroid in forum HTC EVO 4G Hacks
    Last Post: 12-10-2010, 09:56 PM
galaxy s2 cpu runs hot
galaxy s2 hot
my samsung galaxy s2 gets really hot
s2 hot
samsung galaxy hot
samsung galaxy s2 gets hot
samsung galaxy s2 getting hot
samsung galaxy s2 hot
samsung galaxy s2 running hot
samsung s2 gets hot
samsung s2 getting hot
samsung s2 hot
why does the samsung galaxy s2 android get hot
why does the samsung galaxy s2 get so hot
why is my samsung s2 so hot
