Galaxy S2 Running HOT
This is a discussion on Galaxy S2 Running HOT within the Samsung Galaxy S2 forums, part of the Samsung Android Phones category; Has anyone had an issue with their phone running hot? I have had to remove the battery a couple of times since receiving it last ...
Page 1 of 14 12311 ... LastLast
Results 1 to 10 of 136
Like Tree1Likes
Thread: Galaxy S2 Running HOT
    Android Lurker etcromb's Avatar
    I have had to remove the battery a couple of times since receiving it last Thursday. It ran hot, twice after charging via the car charger and one time I just had it in my pocket. When it runs hot it freezes . The heat does not appear to be around the battery but higher, towards the camera.
    Once the battery is removed, I have replaced it immediately and the phone then runs perfectly.
    Confusing.
    190 times
    FurryVarmint
    That's the antenna/CPU area. Are you streaming data heavily? IF so that'd do it. If you're in a low-signal area then that'd do it as well as the radio boosts its broadcast power to compensate.
    DO NOT WRITE IN THIS SPACE
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Bluetooth will also make a good deal of heat when charging. I'd recommend looking at a task manager to see what's running when it's starts getting hot. I've only had it do that once and I found out it was an app that had gone crazy and was sticking the processor at it's max 1.2GHz the whole time it was charging. When it's maxed out, it gets warm quick.
    EDIT: If you're rooted, use this: https://market.android.com/details?i...=search_result
    Somewhere on Kamino
    67 times
    Those are both great points that could be a cause with overheating. If it always overheats when charging in the car it may wind up being too much current going into the phone. This can be from a faulty car charger or one that wasn't made by manufacturer.
    190 times
    FurryVarmint
    Oh, did you have GPS enabled? That can fry your phone with the heat it generates if it can't find a signal. Was a BIG problem on the D1 till FroYo hit.
    Android Lurker Grapes's Avatar
    Jun 2011
    Mine runs hot as heck sometimes but i've never experienced any issues with it freezing...
    Android Lurker avedis's Avatar
    Jun 2011
    Hi, Im new here and in Android OS, but isnt it mean thet there is something wrong with this phone? I mean its not suppose to be heating that much as a Flagship phone. And isnt it bad to be arround when it boost its broadcasting - all this radio waves.....
    190 times
    FurryVarmint
    If it's getting too hot to touch then take it back. That's not right at all.
    As for radio waves, yes, they can be unhealthy in large doses and from long-term exposure. That's why the devices have a deflector preventing the radio waves from broadcasting towards the front of the phone at anywhere near the strength they broadcast from the rear. That's also why the antenna in many phones was moved to the bottom of the phone, closer to the jaw, than at the ear-piece, where more radiation would be absorbed by the brain.
    Android Lurker bmmt's Avatar
    Jun 2011
    Mine is running hot sometimes, too. When im playing, when im using the phones to the radio, when im charging the device. Something that i notice is that when im recording in full hd the camera focus never stop focus.... anyone experience that? Sorry my english hope you understand. thanks
    El Paso, TX
    56 times
    _B0BB0_
    How hot is hot? Use an app like temp monitor to check.
  1. Why More Services Are Running in RAM
    By rajeshgalla in forum Samsung Galaxy
    Last Post: 02-26-2012, 12:03 AM
  2. Replies: 0
    Last Post: 10-16-2011, 10:50 PM
  3. Replies: 0
    Last Post: 09-07-2011, 04:58 AM
  4. Running Services
    By GrahamF in forum Android Forum
    Last Post: 03-14-2011, 04:31 AM
  5. What rom are you running on the EVO 4G?
    By danDroid in forum HTC EVO 4G Hacks
    Last Post: 12-10-2010, 09:56 PM
galaxy s2 gets hot
galaxy s2 getting hot
galaxy s2 heat
galaxy s2 heating problem
galaxy s2 hot
galaxy s2 overheat
galaxy s2 overheating
galaxy s2 running hot
samsung galaxy s2 gets hot
samsung galaxy s2 getting hot
samsung galaxy s2 heating problem
samsung galaxy s2 hot
samsung galaxy s2 overheat
samsung galaxy s2 overheating
samsung galaxy s2 overheating problem
