Extreme overheating s2
This is a discussion on Extreme overheating s2 within the Samsung Galaxy S2 forums, part of the Samsung Android Phones category; Yes, most cpu can handle up to 170 F or 76.6 C before it can cause problems. That however does not mean you want it ...
Results 11 to 15 of 15
Like Tree1Likes
Thread: Extreme overheating s2
    Somewhere on Kamino
    83 times
    Yes, most cpu can handle up to 170 F or 76.6 C before it can cause problems. That however does not mean you want it operating at those temps. Most hardware around the cpu is rated at 158 F or 70 C which is why manufacturers have the phone power off at that temperature.
    Ollie likes this.
    Android Sr Member Ollie's Avatar
    8 times
    Ah I see. That seems rediculously high is all.
    Somewhere on Kamino
    83 times
    Oh I agree. You should see the temps I had my friends pc running at. :D glad we intercooled it. Had 1st gen i7 2.6 Ghz running at just shy of 3.7 Ghz. Then we intercooled it. :D
    8 times
    I am running the i7 as well. Loving it.
    Android Lurker ideasrj's Avatar
    Hi, I bought Samsung galaxy S2 on 10th of this month from Carrefour City centre, Sultanate of Oman. The handset heats up and gets so hot that it burns ear and the palm feels the heat. All this happens if the phone is used over 20 minutes either to talk or download apps or browsing net. While charging, the phone cant even be touched because of its high temperature and strangely, it is advised by Samsung that one should not use the phone for any other purpose while the battery is getting charged !! It was not for this I parted my money. I bought this phone confidently believing in the touted capabilities of it, but am now running pillar by post to get a refund from the retailer.. I posted this experience in Samsung's Facebook wall but no response..
  1. Droid X Overheating Like CRAZY!!
    By dragyn331 in forum Motorola Droid X
    Last Post: 07-04-2011, 07:50 PM
  2. Did my phone turn off to stop overheating?
    By Invisible Crane in forum Samsung Galaxy S2
    Last Post: 06-20-2011, 06:05 PM
  3. Overheating...
    Last Post: 01-12-2011, 11:31 PM
galaxy s2 heating up while charging
galaxy s2 overheating
galaxy s2 overheating fix
galaxy s2 overheating when charging
galaxy s2 overheating while charging
samsung galaxy overheating while charging
samsung galaxy s battery overheat
samsung galaxy s2 battery overheat
samsung galaxy s2 overheating
samsung galaxy s2 overheating damage
samsung galaxy s2 overheating fix
samsung galaxy s2 overheating when charging
samsung galaxy s2 overheating while charging
samsung galaxy s2 overheating#gsc.tab
what's the solution when my samsung galaxy s2 overheat?
