Extreme overheating s2
This is a discussion on Extreme overheating s2 within the Samsung Galaxy S2 forums, part of the Samsung Android Phones category; Hi guys, Here's what happened. My phone battery just went down to <5% so i took it into my room and charged it. 10 minutes ...
Results 1 to 10 of 15
Like Tree1Likes
Thread: Extreme overheating s2
    Android Lurker gerrard912's Avatar
    Kulai, Malaysia
    Hi guys,
    10 minutes into charging i heard a beep sound and went to take a look.
    There was a message stating the phone is overheating and battery charging has been stopped.
    I picked the phone up it was like 70 degrees !!!!
    Turned it off and begin charging once again, everything normal now.
    Do you guys think my phone would be damaged by the extremely high temperature ?
    What should i do, i just bought this phone for less than a week..should i take it back to the store and have them replace a new one for me ?
    Any advices would be very much appreciated
    Somewhere on Kamino
    83 times
    70 degrees f or c? If it shut your phone down; it did so your phone did not get damaged.
    Kulai, Malaysia
    hey i think it's around 60-70 degrees celcius..it's really hot till i was thinking it's gonna explode..is there a chance it might burn the components in the phone ??
    Somewhere on Kamino
    83 times
    It shouldn't but, if it gets that hot again you may want to replace it. Are you rooted using an overclock rom?
    Kulai, Malaysia
    Nope, not rooted..din't installed any unique apps..even it's charging now it's 48-52 degrees celcius
    Somewhere on Kamino
    83 times
    Then you should be fine. I would keep an eye on it over the next couple of days.
    Kulai, Malaysia
    Okay, thanks alot
    Android Sr Member Ollie's Avatar
    8 times
    70 is far too high. Your other temps listed are quite normal though. I never charge my battery while it is in the phone. I purchased a wall charger that charges my spare batteries.
    Somewhere on Kamino
    83 times
    70 is about what we have when we overclock the cpu. It will shut off the phone prior to damaging the cpu.
    8 times
    70 celsius?!
  1. Droid X Overheating Like CRAZY!!
    By dragyn331 in forum Motorola Droid X
    Last Post: 07-04-2011, 07:50 PM
  2. Did my phone turn off to stop overheating?
    By Invisible Crane in forum Samsung Galaxy S2
    Last Post: 06-20-2011, 06:05 PM
  3. Overheating...
    Last Post: 01-12-2011, 11:31 PM
galaxy s2 heating up while charging
galaxy s2 overheating
galaxy s2 overheating fix
galaxy s2 overheating when charging
galaxy s2 overheating while charging
samsung galaxy overheating while charging
samsung galaxy s battery overheat
samsung galaxy s2 battery overheat
samsung galaxy s2 overheating
samsung galaxy s2 overheating damage
samsung galaxy s2 overheating fix
samsung galaxy s2 overheating when charging
samsung galaxy s2 overheating while charging
samsung galaxy s2 overheating#gsc.tab
what's the solution when my samsung galaxy s2 overheat?
