quick tip to extend battery life
This is a discussion on quick tip to extend battery life within the Samsung Galaxy S2 forums, part of the Samsung Android Phones category; i have done tests over the past couple of days and figured out that your battery will last a lot longer if you turn off ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Like Tree1Likes
Thread: quick tip to extend battery life
    Android Lurker galaxys2guy's Avatar
    i have done tests over the past couple of days and figured out that your battery will last a lot longer if you turn off the wifi when you are not using it. i know the phone will switch off wifi when you leave your house and go back on 3g or 4g but if you manually switch it off when you leave the phone will stop searching for wifi signals when your out thus not using battery power.. it really helps out a lot. for example yesterday i left it on and by 2pm i was down to 68% (it was on battery since 7am) and today i turned it off at 7am when i left and at 2pm it was at 89% and it was pretty much the exact same amout of usage. some texting checking Facebook and twitter 10 mins of gaming.. test it out for yourself and post below if you noticed a difference in your battery life or not
    Sent from my GT-I9100M using Android.net
    Last edited by furbearingmammal; 08-05-2011 at 02:24 AM. Reason: Cleaned up the post.
    Columbia, Misery (Missouri)
    8 times
    not all phones transition between wi-fi and network automatically (my phone for example, Optimus T) and must be manually switched over. When I forget to, you're probably right: constantly searching for the ever-elusive wi-fi connection must require more juice than being connected to (2 or) 3g.
    190 times
    FurryVarmint
    The constant scanning isn't good for battery life, no. All scanning is done at maximum power, so that's a tremendous battery drain.
    Turning off the WiFi has been a known battery-saver since before the Motorola Droid hit. It's just common sense to turn off a radio transmitter when you're not using it.
    DO NOT WRITE IN THIS SPACE
    Android Lurker Eagle81103's Avatar
    Theres an app called juice defender an one called 2x battery install them n ull notice a tremendous difference n ur battery life
    190 times
    FurryVarmint
    Neither one does anything you can't, and shouldn't, do yourself. They also run constantly in the background and actually negatively impact performance/battery life over you doing those things manually.
    Android Sr Member Ollie's Avatar
    8 times
    I used Titanium Backup to freeze most of the useless background apps and the list is quite extensive! Stay away from Juicedefender and apps like that. There is a Wifi quick toggle in the notification bar. That is what I use.
    8 times
    Quote Originally Posted by Ollie View Post
    Is that for rooted phones (TB-U)?
    8 times
    Yes, Titanium is for rooted phones. It is one of the two reasons that I root. Titanium backs up all of your apps with their data for a painless one click reinstall after a factory reset. The second reason I root is for CWM. It creates a complete system image of everything on your phone for yet another painless reinstall when something starts acting up. Including wallpapers, Widgets, apps, photos, music,movies, etc. Everything.
    8 times
    Wow. I've been asking for months why root. Fbm reminded me about being able to ditch those useless factory apps (this thing has many), but I wasn't aware of the CWM aspect. Man, I wish I wasn't afraid to try rooting. I'm bummed...
    Android Lurker zachgross's Avatar
    So juice defender isent worth using ?!
    Optimus V
  1. EVO 3D Battery Life?
    By danDroid in forum HTC EVO 3D
    Last Post: 12-11-2011, 06:34 PM
  2. EVO 3D Battery Life?
    By danDroid in forum HTC EVO 3D Hacks
    Last Post: 06-30-2011, 04:21 PM
  3. need help with battery life
    By shat1019 in forum Samsung Galaxy S2
    Last Post: 06-30-2011, 10:59 AM
  4. Battery life
    By Kendrickroad in forum Samsung Epic 4G
    Last Post: 06-09-2011, 07:33 PM
  5. Low battery life
    By cybersenior in forum Samsung Intercept
    Last Post: 03-19-2011, 04:19 PM
droid avatar
droid avatar pics
galaxy s2 prolong battery life
how to extend battery life galaxy s2
how to prolong battery life for samsung galaxy s2
how to prolong battery life on samsung galaxy s2
how to prolong galaxy s2 battery
how to prolong samsung galaxy s2 battery life
how to prolong samsung s2 battery life
how to save battery life on htc evo 3d
prolong battery life samsung galaxy s2
prolonging galaxy s2 battery
samsung galaxy s2 prolong battery life
samsung galaxy s2 prolonging battery life
samsung s2 how to save battery
