Media scanning problem
This is a discussion on Media scanning problem within the Samsung Galaxy S2 forums, part of the Samsung Android Phones category; hi this is the problem in my Galaxy S2 Gingerbread 2.3.3 I have 16 GB of SD it was before every time I add mp3 ...
Thread: Media scanning problem
    Android Lurker roysolid2's Avatar
    hi
    I have 16 GB of SD it was before every time I add mp3 in my music file on the SD it appears in music player and also my video it appears in Gallery
    but after sometime it doesn't adding the files with Samsung Kies or by normal connecting the usb it will be the same problem
    then I perform clear data on media storage and music and restart my Galaxy S2 and sometimes it works again but it's mix my contact raining tons
    and after some copy times it returns to the same problem
    when I disconnect the mobile from PC it gives
    1-media scanning running
    2-media scanning complete
    but nothing new is add to the files
    and if I go to My file App the music and videos are add to the SD
    and If I use other Media player Like MX Player I only need to press video scan and the new files are shown
    so what cause this problem ?
    I tried installing startup manager but even so disable media storage and adding other manual scanning didn't help
    so the problem is the media scanner doesn't recognize the files are add after sometime
    my Galaxy S2 info
    android version 2.3.3
    baseband version I9100xxkg1
    Karnel version 2.6.35.7-I9100jpkg5-cl428948 root@dell137 #2
    build number gingerbread.jpkg5
    flash and rooted from this files
    CF-Root-SGS2_JP_XSG_KG2-v4.1-CWM
    JPKG5 Stock Kernel:
    CF-Root-SGS2_JP_XSG_KG2-v4.1-CWM4.tar
    please help because this is driving me crazy
    Android Sr Member Ollie's Avatar
    8 times
    I have to reboot my phone to allow the media scanner to detect new files I have added. Have you tried this?
    yes but nothing is it faulty JPKG5 Stock Kernel or a program i have ? doing this?
    8 times
    I am not sure. I am running UHKG7 which is the new Gingerbread 2.3.4 It works fine for me.
    the problem the arabic support is only in 2.3.3
  1. Galaxy S2 - Media Scanning Stops Music Play Back
    By skully78 in forum Samsung Galaxy S2
    Last Post: 04-30-2012, 05:49 PM
  2. Media Problems
    By ChrisBTrappiN in forum Samsung Captivate
    Last Post: 09-29-2011, 06:23 AM
  3. Freezing & Corrupted Media
    By VorlonShadow in forum Android Graphics
    Last Post: 06-22-2011, 07:23 AM
  4. Google media hub
    By Kcg2x in forum LG G2x
    Last Post: 06-07-2011, 03:53 PM
android media scanner keeps running
android media scanner running
galaxy s2 media scanner
galaxy s2 media scanner running
how do i stop media scanner from running on the skyrocket
media scanner running android
media scanner running lg thrill
media scanner running on s2
media scanner running samsung
media scanning problem in samsung
my phone keeps saying media scanner running
samsung galaxy s2 media scanner keeps running
samsung galaxy s2 media scanner running
why does my media scanner keeps running
