Can't turn wifi off after turning on wifi direct. please help
This is a discussion on Can't turn wifi off after turning on wifi direct. please help within the Samsung Galaxy S2 forums, part of the Samsung Android Phones category; I accidentally turned on WiFi Direct, and now i can't get back into the Direct settings to turn it off. Whenever i go into any ...
Thread: Can't turn wifi off after turning on wifi direct. please help
    Android Lurker Franklin's Avatar
    I accidentally turned on WiFi Direct, and now i can't get back into the Direct settings to turn it off. Whenever i go into any of the settings to turn off the wifi it completely freezes for up to ten minutes until it says application settings not responding and i can force quit it.
    I need to use my phone as a wireless hotspot, and not being able to turn off the wifi prevents me from doing it, what do i do??
    Android Lurker coolnmv's Avatar
    Dec 2011
    I got the same problem wid my Galaxy S2 . Had to wipe and hard reset for it to stop and i tried again its back to the same state
    197 times
    FurryVarmint
    Does putting the phone in Airplane mode do anything to help the situation?
    DO NOT WRITE IN THIS SPACE
    Somewhere on Kamino
    83 times
    Which galaxy s2? What carrier?
    Android Lurker anjan369's Avatar
    Dec 2011
    Hi, I too have been facing a serious issue with wifi / wifi-direct on my s2 for quite some days. It all started once when i tried connecting to my wifi network at home. The wifi network never got detected (which it would previously) and the scanning continues and is not stoppable. It gives an error message that certain activity is not responding and asks whether to force close. The force close also doesnt help. Initially i figured out the flight mode was helpful in turning off the wifi scanning but when flight mode is switched off the wifi scanning starts again. I tried a new custom rom and also stock firmware but neither helped. The issue crops up mostly when i try selecting wifi-direct. It does not go any further after selecting the wifi-direct menu option, after which it hangs/blanks out and does kind of a short restart (not the complete restart). Please help.
  1. WIFI Problem
    By dolah in forum Acer Liquid
    Last Post: 10-09-2011, 01:16 AM
  2. Wifi strength
    By parmindernangla in forum Samsung Galaxy S2
    Last Post: 08-06-2011, 04:26 PM
  3. Wifi calling
    By ubeiam in forum LG G2x
    Last Post: 06-24-2011, 01:50 AM
  4. WIFI connection
    By jlm226 in forum Android 2.2
    Last Post: 04-21-2011, 06:20 PM
  5. Wifi from desktop
    By Bazar6 in forum Off-Topic Forum
    Last Post: 04-11-2011, 07:28 AM
directv turn off wifi
disable wifi direct
disable wifi direct after use
disable wifi direct galaxy s6
galaxy s6 disable wifi direct
how to disable wifi direct
how to disable wifi direct samsung j5
how to turn off wifi direct
how to turn off wifi direct android
how to turn wifi direct off
turn off wi-fi direct
turn off wifi direct galaxy s6
turn off wifi direct on samsung tablet
