Help with Samsung Kies MTP/ USB Tethering
This is a discussion on Help with Samsung Kies MTP/ USB Tethering within the Samsung Galaxy S2 forums, part of the Samsung Android Phones category; So I just got my phone a few days ago, and I must say I'm quite impressed with the freedom it allows and the files/formats ...
Thread: Help with Samsung Kies MTP/ USB Tethering
    Android Lurker shawn_fiti's Avatar
    Sep 2011
    So I just got my phone a few days ago, and I must say I'm quite impressed with the freedom it allows and the files/formats supported by it etc.
    One thing I haven't figured out though, is.. when I plug the phone into my computer through USB I get the Samsung Kies MTP notification, my computer recognizes the phone, and all is well. But if I quit Samsung Kies by pressing the home button, I can't get the application to run again without unplugging and reconnecting the USB.
    Which leads me to my next problem, tethering through USB. I know how to enable it in the phone, but it feels like I'm supposed to connect the phone, enable the USB tethering, and then go back into Kies which I don't know how to do. Either that or I'm just doing something else wrong, because I can't enable USB tethering before it's connected and when my phone's not in Kies my computer doesn't acknowledge that the phone's connected, so I can't use the internet from it. I've also tried putting the phone in USB storage mode, but tethering can't be done in that mode.
    So basically, how do I re-open the Samsung Kies MTP application without reconnecting the phone, and will that solve my USB tethering issue?
    Android Lurker craig's Avatar
    Sep 2011
    I had the exact same problem, but eventually figured it out.
    I had to install the Samsung Kies application on my PC (Samsung Apps).
    Then, following the same steps as you, when I activate tethering, the USB device is re-initialised on my PC, and I have a 3G connection via USB.
    Plaform: Windows 7 64-bit.
    PS: I had the Samsung Kies application running on my PC when I activated the USB tethering. I haven't tested yet whether this is a requirement.
    C
    Sep 2011
    Thanks! I installed Samsung Kies on my computer, and the USB tethering does seem to work as it should now. It still doesn't want to reconnect to the point of being able to transfer files and such again without unplugging and reconnecting the USB (has a permanent "connecting" message in Kies on the computer), but that's not such a big deal.
  1. Cannot connect to Samsung Kies
    By parmindernangla in forum Samsung Galaxy S2
    Last Post: 09-13-2011, 12:44 AM
  2. Samsung Galaxy ACE GT-S5830 - Kies issue
    By blueman in forum Rescue Squad Help
    Last Post: 07-29-2011, 11:02 AM
  3. Samsung Galaxy ACE GT-S5830 - Kies issue
    By blueman in forum Introductions & Site Assistance
  4. Replies: 6
    Last Post: 06-01-2011, 10:23 AM
  5. Replies: 0
    Last Post: 02-24-2011, 03:35 PM
can kies3 connect usb tethering
can't tether in mtp mode
how to use samsung kies 3 for usb tethering
s5930 samsung kies usb tether
samsung galaxy m style usb tethering
samsung gt b53330 usb teather driver
samsung gt s 5830 tethering error
samsung gt- s5830 tethering
samsung kies needed for tethering
samsung mobile mtp device -- code 18
unable to tether while mtp in click
unable to tether while mtp in use
usb network tethering with samsung kies
usb tethering gt-s5830i
whenever i tether my kies offline
