Very "buggy" when plugged in for charging. Help Please.
This is a discussion on Very "buggy" when plugged in for charging. Help Please. within the Samsung Galaxy S2 forums, part of the Samsung Android Phones category; I have the Galaxy S2 for Sprint. When it is plugged in to charge, it won't let me scroll properly via the touch screen and ...
Thread: Very "buggy" when plugged in for charging. Help Please.
    Android Lurker zyal8r808's Avatar
    Sep 2011
    I have the Galaxy S2 for Sprint. When it is plugged in to charge, it won't let me scroll properly via the touch screen and also the main buttons for home, settings, etc.
    When I disconnect the charger, it works perfectly fine. Any advice is appreciated.
    Super Moderator CJM's Avatar
    MS Gulf Coast
    51 times
    Are you using the factory charger? I've seen these problems described before with aftermarket chargers and non-factory charges.
    Tapped from an Unbrickable DROID
    Sep 2011
    Quote Originally Posted by CJM View Post
    I'm using the charger that came with the phone.
    MS Gulf Coast
    51 times
    Do you have a usb cable that can charge it? Or a friend with the same charger. Some other way to charge it to eliminate that it's the factory charger. It may be bad. Or maybe take it by the store and let them charge it, to show them what it's doing. If it's under warranty, they may be able to you more.
    Sep 2011
    Thanks for the tips. I'll try them.
    Sent from my SPH-D710 using Android.net
    Android Lurker parmindernangla's Avatar
    It happens with me too. Even while charging the keyboard is laggy. But dont know why it happens.
    Sent from my GT-I9100 using Android.net
    Android Lurker grarya01's Avatar
    Oct 2011
    same issue
    same issue, factory charger w/usb.
  1. Gingerbread upgrade changes "Data Connection" to "Sound"
    By atodea in forum Samsung Galaxy Mini
    Last Post: 08-21-2011, 09:28 PM
  2. Replies: 1
    Last Post: 07-07-2011, 02:13 PM
  3. Replies: 0
    Last Post: 05-19-2011, 06:11 AM
  4. Replies: 5
    Last Post: 03-24-2011, 01:42 AM
  5. Replies: 0
    Last Post: 02-02-2011, 03:27 PM
android phone screen buggy while charging
android phone wont charge when plugged in
galaxy s2 buggy
galaxy s2 dies while charging
galaxy s2 touch screen problem while charging
galaxy wont charge on non factory chargers
keep samsung galaxy s4 screen on when charge cable plugged in
mini piscina bolinha
nexus 4 buggy touch screen
samsung galaxy s2 bad connection for charging
samsung galaxy s2 trouble charging
samsung galaxy tab charging screen unresponsive
samsung s2 touch screen lag while charging
samsung s2 wont work after charging properly
samsung tab touch screennot working when pluged in
