Messaging Problem
This is a discussion on Messaging Problem within the Samsung Galaxy S2 forums, part of the Samsung Android Phones category; Hey guys, im using a galaxy s 2 at the moment, android 2.3.3 When i get a txt message, the tread window pops up right..when ...
Results 1 to 8 of 8
Thread: Messaging Problem
    Android Lurker nazaaron's Avatar
    Sep 2011
    Messaging Problem
    When i get a txt message, the tread window pops up right..when i click on the 'tap to enter message' box the box becomes bigger and the keyboard comes up as well.. but when i start to type keyboard nothing happens??
    So I click lots of buttons on the keyboard..tap the box multiple times..nothing seems to trigger the start of message (if you know what i mean) .... only after some time of waiting and random button pressing then it magically starts to work... anyone know why this is happening.. because it shouldn't.
    maybe its just lagging??
    Any help/ suggestions will be helpful
    Cheers
    Aaron
    Sep 2011
    any1 else havin this problem??
    Super Moderator CJM's Avatar
    MS Gulf Coast
    51 times
    This might be a long shot, but you could try going into settings/applications/manage applications/all then select the keyboard(not sure what it will be called, in my original Droid its Android Keyboard) then select Clear Data. Hope this helps.
    Or maybe try a replacement keyboard from the market and see if the problem persist. If so, it could be the app. If so, I would go through the same process to Clear Data.
    Tapped from an Unbrickable DROID
    Columbia, Misery (Missouri)
    8 times
    I just back out of it and start again when that happens. Inconvenient but works. It does'nt happen very often so I haven't complained.
    Sent from my SGH-T989 using Android.net
    Sep 2011
    hey guys thanks for that..
    im using a samsung.. and in the manage applications thing.. there was 'samsung keyboard' & also 'swype'.. so yeah i did the clear data/cache so lets c if it works.. ill let you know in a couple of days
    like titanoman said it doesnt happen very often (but when it does, it does get quite annoying)
    Cheers
    Aaron
    Android Lurker budwiser's Avatar
    Sep 2011
    Hi, I just wanna to know is anyone here having problem with their samsung s2 especially while making calls, ie: voice not clear. This is because I got lot of complaints from my friends sometimes they cant hear me speaking though im not using a handfree or speaker. Please assist
    Thanks
    Sent from my GT-I9100 using Android.net
    Sep 2011
    about the messaging problem.. clearing cache didnt do much to help..so i installed Touchpal keyboard from the market..trying that for about a week now.. worked fine for a couple of days but still lags a bit sometimes...
    lags less then the samsung so thats good i guess...
    any1 got any other ideas that might help??
    Sep 2011
    @Budwiser ........ could be your reception thats causing the problem...??
  1. Replies: 3
    Last Post: 08-18-2011, 05:21 PM
  2. Replies: 0
    Last Post: 12-31-2010, 02:57 PM
  3. Recommended Text Messaging Apps for G2
    Last Post: 11-25-2010, 06:46 PM
android messaging problems
android texting problems
galaxy s2 texting issues
galaxy s2 texting problems
galaxy s2 typing problem
samsung galaxy messaging problem
samsung galaxy s2 messaging problems
samsung galaxy s2 text problems
samsung galaxy s2 texting not working
samsung galaxy s2 texting problems
samsung galaxy s2 troubleshooting texting
samsung galaxy s2 typing problems
samsung galaxy s5 text messaging problems
samsung s2 messaging problem
texting problems with galaxy 2
