Galaxy S2 Battery Problem
This is a discussion on Galaxy S2 Battery Problem within the Samsung Galaxy S2 forums, part of the Samsung Android Phones category; For some reason my mobile is drains quickly, I am not using any WIFI, GPS etc., Some times when the mobile is left in idle ...
Thread: Galaxy S2 Battery Problem
    Android Lurker Srini's Avatar
    Oct 2011
    For some reason my mobile is drains quickly, I am not using any WIFI, GPS etc., Some times when the mobile is left in idle state over the night, by morning i see that battery has completely drained out. I closed all the application but it still happens. Also I use System power saving settings. Any one has the same problem?
    Is there any tool that removes the back-end unnecessary services automatically when they are not in use?
    Any other solution to increase the battery performance?
    Thanks in advance!
    Android Lurker RichieScouse86's Avatar
    Oct 2011
    Liverpool, United Kingdom
    @RichieScouse
    Hi,
    Try switching off your 3G, Its a massive drain on the handset....If you go into settings-applications-battery usage this gives details on the things that are relied upon due to battery, the main top usgae should be the display in which case switch auto rotaion off, brightness should be set to about 2 from the end and time out should be set to about 1.5 secs.
    So in short this is what you should do to ensure your battery life is fully strecthed out and saved:
    Power Saving Mode - @50%
    Brightness - 2 from the end on the slider thingy
    3G - OFF
    Auto Rotation - OFF
    An obviously WiFi,GPS and the other apps that you know use life up.
    Its now 2.15 and my phone is saying I still have 8 hours left on my battery due to these options I have just explained....plus I've been surfing on the marketplace a few times, an watched a video...which is still good consumption.
  1. Samsung Galaxy S2, Battery Problem
    By Terje in forum Samsung Galaxy S2
    Last Post: 03-16-2013, 03:42 AM
  2. Battery Galaxy Mini and the data cable
    By Zaid in forum Samsung Galaxy Mini
    Last Post: 09-15-2011, 02:20 AM
  3. galaxy pop gallery problem
    By balan in forum Rescue Squad Help
    Last Post: 09-08-2011, 04:26 AM
  4. Samsung Galaxy S2 ......Gtalk Problem
    By soumyatito in forum Samsung Galaxy S2
    Last Post: 08-23-2011, 10:01 AM
  5. Replies: 3
battery drain galaxy s2
battery problem with samsung galaxy s2
battery problems with samsung galaxy s2
galaxy s2 battery drain
galaxy s2 battery drain fix
galaxy s2 battery fix
galaxy s2 battery issues
galaxy s2 battery problem
galaxy s2 battery problems
s2 battery problem
samsung galaxy s2 battery drain
samsung galaxy s2 battery issues
samsung galaxy s2 battery problem
samsung galaxy s2 battery problems
samsung galaxy s2 problems with battery
