Has the Echo Problem Been Fixed Yet?
This is a discussion on Has the Echo Problem Been Fixed Yet? within the Samsung Galaxy S2 forums, part of the Samsung Android Phones category; I am considering getting a Samsung Galaxy S2 in the near future but am concerned by reports of echo problems when used with a case. ...
Thread: Has the Echo Problem Been Fixed Yet?
    Android Lurker Jonny_a's Avatar
    Dec 2011
    I am considering getting a Samsung Galaxy S2 in the near future but am concerned by reports of echo problems when used with a case. Extract from Amazon review below:-
    >ECHO PROBLEM
    >There is a serious issue with the Samsung Galaxy S2 that needs to be brought to light, namely the "echo" problem when the phone is used with a protective case such as the Case-Mate Tough Case, or any other case for that matter. This fault has affected a number of SGS2 users. Just Google "galaxy s2 echo problem" and you'll see what I'm talking about. Unfortunately, if your phone is affected then you're one of the unlucky ones because, as I found out, it is a hardware fault with the phone!
    Has this issue now been resolved in new Samsung S2 phones via a hardware or firmware upgrade??
    This looks like a serious issue as I will want a case for my Samsung Galaxy S2, there seems little point buying a phone I can’t talk to people on.
    Please let me know your thoughts.
    Jon.
    Administrator danDroid's Avatar
    43 times
    droidforums
    Hi Jon and welcome to Android.net. I've heard the same thing but haven't experienced it first hand. What version (carrier) of the Galaxy S2 are you considering?
    Android Lurker bel_vodka's Avatar
    Jan 2012
    I think I'm one of the victim ..
    Im going to bring down n request for servicing...
    sad to the max
    Sent from my GT-I9100 using Android.net
    Android Lurker hazi's Avatar
    Mar 2012
    The echo can be got rid of during a call if you press settings then noise reduction off. Happens to me on some calls and doing this gets rid of the echo.
    You can't do it on speaker phone though and you have to do it each call when necessary as there is no option to permanently turn the noise reduction off.
    Not all calls have the echo anyway so you only need to do it when it happens.
    Works a treat for me.
  1. Can This Be Fixed?
    By kntrygurl in forum Samsung Galaxy S2 Skyrocket
    Last Post: 03-06-2012, 02:06 AM
  2. Replies: 0
    Last Post: 02-15-2012, 10:52 AM
  3. samsung galaxy mini ECHO problem
    By serjode in forum Samsung Galaxy Mini
    Last Post: 01-05-2012, 01:49 AM
  4. 50% Bug Fixed with Update??
    By stingrayracing in forum LG Ally
    Last Post: 11-26-2010, 07:35 AM
  5. Sprint has EVO update available again, should be fixed
    By Admin in forum Sprint Android News
    Last Post: 07-05-2010, 11:41 AM
echo problems with samsung galaxy s2
galaxy s2 echo fix
galaxy s2 echo solution
samsung galaxy s2 echo fix
samsung galaxy s2 echo issue
samsung galaxy s2 echo problem
samsung galaxy s2 echo problem solution
samsung galaxy s2 echo problems
samsung galaxy s2 echo solution
samsung galaxy s2 skyrocket echo problem
samsung s2 echo
samsung s2 echo fix
samsung s2 echo problem
sgs2 echo problem
