Android Lurker
Samsung Galaxy S2 WiFi Problem
I am facing the problem, that my galaxy s II connects to wifi but none of the applications like market share and Google Maps are working, it shows
"A network error has occurred.retry or cancel and return to the previous screen". Moreover the wifi has good signal strength. can u please tell me what can i do ??
05-06-2012 07:59 PM
# ADS
Super Moderator
Hello elsawy, and welcome to the forum!
Super Moderator
Hello, Does the browser work? Have you tried mobile network? And the device you are connecting, does it have a working network connection? Did you try to connect to a different device? Answer these questions, and I'll see if I can help you. If not, hopefully someone else will come by and help you out.
When people run in circles,
it's a very very mad world.
Tears for Fears
Android Lurker
the browser worked when i used 3g connection and the market worked too .. and i tried other networks but it shows the same error ,, the network im talking about at first is my own network so im sure its working it worked with my previous phone and laptop ..
Thx 4 caring and replying .. i hope u can solve this :D
Super Moderator
Try going to Wi-Fi settings. And tick static IP if off. If it's on, try reseting it. It fixed for my friend once. Also try reseting sleep policy. Even if it doesn't make sense, it usually fixes similar issues. If it's "never" then choose a different one and then back to "never".
Tears for Fears
Android Lurker
Same issue
I'm having the same issue but it seemed to have started after I did a firmware up date. And it's very frustrating please help
Android Lurker
I've been having the same problem. I've tried a couple things that seem to help but not permanently... Try turning the wifi off and then back on. (I'm getting a new router this week just to see what that does).
Change wifi settings and Set "Keep Wi-fi on during sleep" to "Only when plugged in".
For 3g data issues, I changed my roaming settings (even if you're not roaming this may help). I put a check next to Voice and Data for both Domestic and International and that seemed to help for whatever reason...
I seem to randomly have problems with my data whether it's wifi or 3g/4g. I usually first notice the data problems when using the app store and updating apps.
Android Lurker
same issue - any fix?
I'm having the same issue - although it only started this week and I updated the firmware ages ago. very frustrating. The IP static setting is greyed out on mine though.
Android Lurker
I have same problem, I have bought Samsung Galaxy S II and I need wireless Internet connectivity on it, but it does not work.
Super Moderator
Welcome to the forum - EVERYONE!
