Galaxy SII Rattling Sound When Shaking?
This is a discussion on Galaxy SII Rattling Sound When Shaking? within the Samsung Galaxy S2 forums, part of the Samsung Android Phones category; I just read about this and tried shaking the phone and I can indeed hear a rattling sound. Is this supposed to be here? My ...
Thread: Galaxy SII Rattling Sound When Shaking?
    Android Lurker galaxys22's Avatar
    Jul 2012
    I just read about this and tried shaking the phone and I can indeed hear a rattling sound. Is this supposed to be here? My device does not seem to be faulty. What do I do?
    i found that when you shake your phone to the front hardly... it makes a weird noise a "thick" like something is loose inside of the phone on the camera area... I've tried removing battery sim card and sd card and shaking the phone again! there is that noise...
    is that normal!!!
    Somewhere on Kamino
    83 times
    Probably your battery unless you dropped your phone. Try snapping your back cover down just to make sure.
  1. Rooted Galaxy S2 Post Boot Sound Nuisance
    By sl1dememphis in forum Rescue Squad Help
    Last Post: 05-30-2012, 12:50 AM
  2. No Sound from Phone's speakers, but sound from earphones?
    By lalaworld123 in forum Samsung Captivate Tech
    Last Post: 10-25-2010, 05:40 AM
galaxy s3 loose inside
galaxy s3 rattle
galaxy s3 rattling noise inside
gs3 rattle sound
rattle sound when galaxy s3 phone is shaked
rattling noise in galaxy s3
samsung galaxy s iii rattle noise
samsung galaxy s2 rattling noise camera
samsung galaxy s3 rattle
samsung shake sound
shake samsung galaxy noise
shaking galaxy s3
when i press something on my galaxy 2 it makes a wierd noise like something is loose
when shake galaxy s2
why does the galaxy s3 make a sound whem you shake it
