S-Planner Problems
This is a discussion on S-Planner Problems within the Samsung Galaxy S3 forums, part of the Samsung Android Phones category; Wow that is annoying - I wish I had more experience with Android to suggest a fix. I wonder if it has something to do ...
Android Lurker
Wow that is annoying - I wish I had more experience with Android to suggest a fix. I wonder if it has something to do with stuff on the SD card. I have heard that getting apps on and off them is a 'black art'.
There must be an option to reset the phone (a pain having to download updates etc) but it might sort out the way the system treats memory?
I think I would try and uninstall them or switch them off in the system menu first though. If you press and hold the app on the S3 you get a sub menu with options to delete. Also the button on the bottom left of the phone will give further menu options once an app is selected.
Good luck
Android Lurker
Last night the phone downloaded the latest firmware (all by itself) and informed me. Still no fix to the SPlanner and some annoying visual changes.
Android Lurker
Use the google calander fix. Takes and extra 30 seconds. No biggie
Android Lurker
The phone downloaded the latest update and rebooted, but no fix to S-Planner.
- You may not post replies
- You may not edit your posts
Forum Rules
By chovik in forum Samsung Galaxy S3
Last Post: 11-30-2012, 01:20 AM
By katonaf in forum Android Forum
Last Post: 07-08-2012, 10:12 AM
By rjgall in forum App Announcements
Last Post: 05-18-2012, 06:42 PM
By ComboApp in forum Android Apps
Last Post: 04-26-2012, 09:04 PM
android s planner
how to reset s planner
s planner
s planner android
s planner app
s planner for galaxy s2
s planner keeps crashing
s planner problem
s planner problems
s planner samsung
s planner widget
s-planner
samsung s planner
samsung s3 s planner
splanner
