Android Lurker
S-Planner Problems
I have just bought the Samsung Galaxy S3 with Ice Cream Sandwich. I love the phone and Android system. However I am trying to find a way to get events in the S-Planner app. to repeat every 2 weeks. The choices are annually; monthly (by day or date); weekly and daily. Any suggestions as to haw to fix this? (The iphone crowd in the house just think this is too funny)
07-30-2012 01:03 AM
# ADS
Super Moderator
Android Lurker
S-Planner Every 2 weeks
I have a galaxy note and with S-Planner and you could set an event to repeat ever 2 weeks
I have done an update and now it can Not set an event to repeat every 2 weeks
Only a total retard would create a New version of an app that has less options than the older version
I trust somebody at android will see this and ensure the 2 week option is put back ASAP
Android Lurker
Well I hope so too SpaceMonkey, I looked at the older version on the 'Note' and saw you could set a 2 week repeat, so presumed.... the mother of al... anyway - the latest version doesn't have the option and I can't even find a place to bring this to the attention of someone who might be able to input into such an app update.
Android Lurker
I wonder if Samsung have taken steps backwards and removed features because of the dispute by Apple
The 2 week feature was available in my iPhone
so Apple may of claimed this is one of the features copied ?
Anyhow I have discovered that if I go into Settings - Applications - All
there numerous apps in the phone that I can not access such as:
Zinio
Trim
Photo Wall
Kobo
Face Unlock
Blue Sea
Aurora 2
AND besides S-Planner version-4.0.4
There is Alsp S-Planner Widget version 1.0
but I can not access S-Planner Widget
Plus there are aleays 20+ apps running
you can use Tack Manager close Active Apps and Clear RAM but when you tap Clear Memory
it says 20+ apps closed
but you go directly back to the home screen and then directly back to Task Manager - RAM
then tap Clear Memore again the 20+ apps you closed have all started again
I would like to know which apps are unnecessary and can be permenantly disabled
Android Lurker
I don't think that the app has had the 2 weekly repeat removed as a result of the apple fiasco! The app is an App and separate from the system and hardware. What happened to your 2 weekly repeats, when you downloaded the update and lost the 2 weekly repeat function?
Interesting... with the Galaxy S3 you don't see the background system apps running until you go into the memory usage in the system. The face unlock etc works and is an option. Have you installed these apps you have found? I have pages of aps on the phone buit to use them each must first be installed and given a short cut on a page on the phone, until then they stay on the Apps area. I found the Widget on line but it doesn't seem to add anything to the App. I think I will await the next update.
Try going into settings and switching off things you don't want. I turned my wiFi off as I pay to download loads I don't use - due to the fact that the phone will migrate onto any active WiFi it can instead of using the mobile allocation. Seems like paying twice to me - once for the WiFi and once for unused data on the phone.
Android Lurker
I have a Galaxy Note and a Galaxy S2
on the S2 it has Calander instead of S-Planner however Calander works Exactly the same
but on Calander on the S2 the 2 week option is still available
When I downloaded the Galaxy Note update all my 2 weekly events were erased
I can not see All the apps that are Running
If I goto Settings-Applications
there are tabs labeled Downloaded, On SD Card, Running, All
If I use the Running tab it olny shows some of those that are running
if there are 18 shown as running how is it when I use task manager to close apps it closes 25+ apps
The phone has 808mb of ram
700mb of that is being used by unidentified apps
if I did another update in the future the apps would use all the ram
and I wont be able to run apps that I have downloaded
All the apps I have downloaded are exactly where they should be
The apps / Widges I have found are simply hidden away and can be seen Only
by going to Settings-Applications-All
but from there you can not use them or even tell what they do
I want to delete or disable any and all unnecessary apps
but it is very difficut to find information about what is safe to delete or disable
and I want access to the S-Planner version 1.0 widget but seem to be unable to use it
Android Lurker
Originally Posted by
smjones
I noticed this issue also, I hope it will be fixed properly in a future update.
In the meantime, I used a workaround by going on to google calander on a desktop and creating an event on there with 2 weekly reminders. It synced up perfectly.
Problems are; you can't set reminders (so far as I can tell, except for the email reminders), and if you modify the event in any way from the phone it will default to weekly repeats so you have to handle it from a desktop (Maybe the desktop version of the phones browser).
But that's still a pretty useable fix.
Android Lurker
Just realised if you have a device with an older version of android (I have a galaxy tab 7 inch original) that you can create an event on there with fortnightly reminders with a notification /reminder. And it will sync with the s3 fine. Just can't edit from the s3. Annoying...
Android Lurker
TheWolf
That is bizarre! Why would SPlanner accommodate a feature that it took out. I think someone made a mistake on their team and left some code out! The S3 is the only Android device I have at present so I guess I'm waiting for the fix (hopefully they read forums).
Still a great phone and system
