Galaxy S3 S-Planner Problem
This is a discussion on Galaxy S3 S-Planner Problem within the Samsung Galaxy S3 forums, part of the Samsung Android Phones category; Hello everybody! I just got my new phone yesterday, my very first Android. Now, I can't get the S-Planner to actually do any noise/sound... it ...
Thread: Galaxy S3 S-Planner Problem
    Android Lurker Prof_Rikk's Avatar
    Aug 2012
    Hello everybody!
    Now, I can't get the S-Planner to actually do any noise/sound... it only vibrates once!
    I've gone to the S-Planner settings menu and selected a ringtone, I even managed to upload my personal ones into the list. When I tap on it (to select it) it plays the sound, but it doesn't make any sound when it should.
    This is very odd.... any help?
    Thank you very very much in advance!!!!
    Riccardo
    Aug 2012
    Eureka!!!
    I've managed to find the answer to the problem!!!
    Basically I had inadvertently turned off the notifications, while exploring the phone... Mystery solved!
    Android Lurker smooches680's Avatar
    Aug 2012
    Quote Originally Posted by Prof_Rikk View Post
    Hello everybody!
    Riccardo
    I have the Samsung Galaxy S3 phone and no s planner app comes installed on that device only the note.
    Sent from my SPH-L710 using Android.net
    Android Lurker Mini's Avatar
    Aug 2012
    Quote Originally Posted by smooches680 View Post
    You should do, if you press the apps button on the home page and go to the second scroll page, you'll see it third row down fourth column across.
    Android Lurker smjones's Avatar
    Jul 2012
    Perth. WA
    Hi, when I got my S3 I could hardly hear the alert sound and only was aware of the vibrate. What I did was go into general settings on the phone and raised the level of the volume. There are several volume adjustments: for alerts, for ring tones, for phone reception etc. The default sets them at the same visual level and this in no way reflects what the volume will be useful at. Turn the alert volume right up 100%.
    Android Lurker NBAmasters's Avatar
    Sep 2012
    Hello, I have problem with the S Planner - no sound at all, just a vibration... the same as Riccardo.
    I have checked all the settings, everything is checked and again - NO SOUND!!! Any idea where else the problem could be?
    Thanks in advance: KI
    Sep 2012
    Quote Originally Posted by NBAmasters View Post
    Hi again,
    I found the solution from another post in the Problems with the sms notifications and it is:
    "simply make sure your notification button is on!!! its located by the wifi, gps, on so on!! then it should work fine"
  1. S-Planner Problems
    By smjones in forum Samsung Galaxy S3
    Last Post: 09-29-2013, 07:48 PM
  2. Changing S Planner Theme
    By katonaf in forum Android Forum
    Last Post: 07-08-2012, 10:12 AM
email notification splanner
galaxy s3 s planner
no s planner on galaxy 3
s planer no sound
s planner app
s planner app for s3
s planner galaxy s3
s planner not installed galaxy s3
s planner samsung galaxy s3
s planner se detuvo
samsung galaxy s3 s planner
samsung planner no vibration
samsung s planner
samsung s3 planner
where is s planner on galaxy s3
