"Not Registered on Network" + Stuck in Factory Mode ON - No Solution Works
This is a discussion on "Not Registered on Network" + Stuck in Factory Mode ON - No Solution Works within the Samsung Galaxy S3 forums, part of the Samsung Android Phones category; Initial state(stock 4.0.4. ROM): Device was working properly; Could call, could use 3G internet; Everything was good. After CWM zip installing FoxHound ROM : Simptoms: ...
Thread: "Not Registered on Network" + Stuck in Factory Mode ON - No Solution Works
    Android Lurker goliathj's Avatar
    Nov 2012
    • Device was working properly;
    • Could call, could use 3G internet;
    • Everything was good.
    After CWM zip installing FoxHound ROM:
    Simptoms:
    • Could not call; for every GSM/3G interogation to telecom operator I get: "Not registered on network";
    • In my pursuite to fix this, I don't know how, now my device ended in Factory Mode(a yellow box with some debug information appears on my screen and the power button now instantly shutsdown the device and no lock screen available).
    • The IMEI returned by *#06# is different by the one on the back of the device. It's not a generic one "000...", it almost looks like the original, both seem to be valid after some search, but this is odd. I don't know if it was different before installing FoxHound ... never cared.
    What I've tried to do:
    • I've actually feasted on half of internet for a solution to my problems;
    • I've tried to flash with Odin tons of stock firmwares, modems, CSCs, including well known ones, my operator ones(Cosmote), my country ones(Romania) -> no luck;
    • I've tried to restore previous nandroid backups -> no luck;
    • I've tried to CWM zip install custom ROMs -> no luck;
    • I've tried everytime to wipe cache, factory reset, delete dalvik, fix permissions, reset battery stats -> no luck;
    • I've tried all the solutions for the "Factory Mode On" problem, including "echo -n ON > /efs/imei/keystr; chown 1001:1001 /efs/imei/keystr" -> no luck;
    • I don't have an /efs/ backup before installing FoxHound.
    • Used GalaxSim, everything was green, no unlock needed.
    My device is still in the same condition. No one has an answer. Do you have a solution?
    518 times
    Hello Goliathj - welcome to the forum!
    No, I have no idea how you resolve your problem, but I'm not a technician. I have a suggestion though - check out our sister forum Samsung Galaxy S3 Forum which is dedicated exclusively to Galaxy S3 and has a lot of really knowledgeable members and staff. You're almost assured of getting the correct answer over there.
    Super Moderator cali's Avatar
    Sep 2011
    329 times
    Welcome to the site. Hope you are able to find a solution.
    Android Lurker liddlekeith's Avatar
    Sep 2013
    I can help you with the Factory Mode situation but as far as the IMEI is concerned, I have the same problem.
    Android Lurker david007co's Avatar
    May 2015
    Were you able to fix the problem?
    This was a long time ago, can you please let me know how you restore your phone?
    Thanks
  1. Replies: 4
    Last Post: 11-27-2012, 10:03 PM
  2. Stuck in Safe Mode
    By AmiPhoenix in forum Rescue Squad Help
    Last Post: 07-15-2012, 09:31 AM
  3. 7" MID stuck after Factory Reset...please help ???
    By axeman24 in forum Rescue Squad Help
    Last Post: 12-11-2011, 11:39 AM
  4. Replies: 3
    Last Post: 10-09-2010, 02:53 PM
disable factory mode s3
factory mode galaxy s3
factory mode samsung galaxy s3
galaxy s3 factory mode
galaxy s3 stuck in factory mode
how to fix not registered on network galaxy note 2
how to fix not registered on network samsung captivate
how to repair galaxy s3 in factory mode
not registered on network samsung galaxy s3
s3 factory mode
samsung galaxy s3 factory mode
samsung galaxy s3 factory mode repair solution
samsung galaxy s3 stuck in factory mode
samsung s3 factory mode
samsung s3 stuck in factory mode
