Need help
This is a discussion on Need help within the Samsung Infuse 4G forums, part of the Samsung Android Phones category; How do I personalize my ringtones. I have music on the phone but I cant manage to transfer them to my contacts. Please Help thank ...
Results 1 to 10 of 20
Thread: Need help
    Android Lurker nystrongest's Avatar
    Jun 2011
    Need help
    How do I personalize my ringtones. I have music on the phone but I cant manage to transfer them to my contacts. Please Help thank you
    Android Lurker Egidio's Avatar
    Austin, TX
    Generally you need to reduce the music file size to about 15-20 seconds. That is what I did for mine. Once that was done, created a folder in my SD card and labeled it ringtones and put those files there. They show up now when I am assigning them to some of my contacts.
    Jun 2011
    Egidio, thank you
    Android Enthusiast Martin030908's Avatar
    6 times
    make sure when you create the folder 'ringtones' that ALL letters are lowercase.
    shortening the songs to a reasonable length for a ringtone is a nice way to ensure you hear what you want, but you can drop in any size file and it'll be available as a ringtone.
    Android Lurker tvfreakazoid's Avatar
    kali
    how do you shorten it by the way?
    Austin, TX
    I'm sure there is a number of apps out there that can do it. I use the free Audacity.
    kali
    Just to be clear, u use the free audacity app to shorten the music so it can be used as a ring tone and what not?
    Quote Originally Posted by Egidio View Post
    Austin, TX
    That's right. I use Audacity in the computer to shorten the tracks and then I upload the ringtone to my phone.
    kali
    Cool thanks.
    How can you get rid of some of the apps that came with the phone such as att navigator? It wont let me delete it and i prefer not have it because u have to pay for it. Google maps is good enough and it's free. I've read reviews that you can't get rid of them and i was wondering if there is an app that would allowed that.
    Super Moderator CR6's Avatar
    Idaho
    222 times
    Not sure if you're rooted or not, but if not, getting rid of those unwanted apps is easy as downloading GoLauncher. Its got a ton ways to customize your home screens, free themes, etc. AND, it will let you "hide" all of the bloat our carriers fill our phones with.
    Give it a try if you're not ready to root yet.
    Tapatalker!
how do i set a ringback tone for samsung infuse
how do you set a ringback tone on a samsung infuse
how do you shorten songs on your android infuse for ringtones
how do you shorten your ringtones on the infuse 4g?
how to get ringback tones on samsung infuse 4g
how to put ringback tones on samsung infuse
how to set a ringback tone on samsung infuse
how to set ringback tones for fusion 2
how to set up ring back tones on infuse 4g
ringback infuse 4g
ringback tones for samsung infuse
ringback tones samsung infuse
samsung infuse ringback tone
samsung infuse ringback tones
